hi!i´m spanish so my english is quite bad..sorry.
i have now coneccted 1 core module with 18f pic,2 ain modules and 1din.if it works i have another din and 1 dout.ok the problem is that i cant enter on the menu.i think that buttons doesnt work…i tried burning ain64_din128_dout128,and with midiox i see(and in the lcd) that a lot of midi signals comes from ain…but the din??how can i know if it works?
Ground the Pots and the problem is solved (you also can ground the Pins of the jumper which go to the Core - just not the 5V one clearly).
Normally you dont see if the buttons are pressed or not. And also a possible problem is that the PIC is just stuffed up with working up the incoming data drom the AIN.
heya! thanks pay_c!! you are right!! it is because of ain midi messages…a lot of them!! but i still have a problem…i tested all the buttoms..they works fine..but with mios or midiboxV.02 installed i cant enter on the menu,it only displays Ready!..what its wrong??
Hello, Im havin alot of trouble with my DIN. The menu button is the only one that sends data, but a whole lot of it. When I press it the LCD turns on but doesn’t display anything. It stays lit until I press the menu button again, then it displays a row of boxes and dissappears, and the backlight shuts off. The rest of the buttons are non-responsive. I checked them with a DVM for shorts, but couldn’t find any.
You were absolutely right!! There was a small short on my DIN module. With that one corrected, my menu button no longer sends a string of data to MIDI-OX, but now the Snapshot button is doing that, and again none of the other buttons are working. Might there still be shorts somewhere?
BTW-When is the LCD supposed to display the ready message? I haven’t seen this happen yet.
