Help with encoder
Hi, can anyone tell me if these encoders will work? The price is right if they do!
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=2547490807&category=26211
I’ve searched for a spec sheet, but no luck.
Thanks!
They seem to be normal encoders, you might want to ask the seller if he as some spec sheets..
;D
http://www.panasonic.com/industrial/components/pdf/007_ev1113_evqb_dne.pdf
They look good…!! I think…:slight_smile:
* Just noticed they are only 15 pulse and are pcb mount - still a good deal eh…
Hey d2k - Thanks a lot for finding the spec sheet. I searched the panasonic website, but I couldn’t find it. I went ahead and bought 64 of them for $20 us. I figure I can’t lose.
Since it is only 15 pulses, does that mean it takes more rotation to change the valuse from 0 to 127, or does that mean a lower resolution?
Thanks again
Justin
No, that just means that you have to make about 8 turnings to go from 0 to 127.
But TK made some “fast” mode for Encoders (in the SID), which means that if you turn the encoder really fast, it is counting up 3 times faster (1,4,7,11…). Anyhow, you would still need about 2-3 rotations to go up to 127…
Yet another encoder choise question.
It seems that the production of the Alps EC16B24 (http://international1.farnell.com/Search/level_5.jhtml?PRODID=89285&SKUID=87224) encoders has ended. At least I was told so by Farnell. So, the question is now what to use instead? They offered to me EC11B15 (http://international1.farnell.com/Search/level_5.jhtml?PRODID=89283&SKUID=87222) which is twice the price (almost 10e each) and has some switch in it. Maybe some encoders by Bourns? http://international1.farnell.com/Search/level_5.jhtml?PRODID=4803&SKUID=2742 which is about the same price or http://international1.farnell.com/Search/level_5.jhtml?PRODID=62469&SKUID=60408 which looks like an el cheapo model?
Or if someone knows a better option from Finland?
Farnell is one of the most expensive distributors, maybe it’s better to order the parts from a scandinavian shop - see also this article:
http://www.midibox.org/cgi-bin/yabb/YaBB.cgi?board=scandinavian;action=display;num=1048720464
Some words to the resolution: it depends on the application which encoders are the best for you. In the meantime I prefer a reduced resolution for MIDIbox SID so that I’m able to change the values more precisely. The progressive mode (Speed Setting) still allows to sweep over the full range with a single turn.
Pay_c: you possibly have to change the CS_MENU_ENC_SPEED_VALUE in main.asm for a higher acceleration on fast turns.
I got all the other parts already from a cheaper dealer, but the encoders seem to be somewhat rare to the local shops here. So, when needing just one encoder, there is no use in ordering them e.g. from Sweden. Luckily, I got one local dealer to order the encoder from RS Electronic when they order some other stuff from there. Hopefully it’ll be ok.
(Extending my one-SID -box to dual-SID with the minimal control surface.)  :)
Ok, I got my encoders today, and I am just trying to get one to work on my test board. I only have one hooked up to one 74HC165. I do have all the 10k resistors on all the inputs. I am using the din_enc_v1 firmware from the test programs portion of the MBHP. When I turn the encoder, it registers the correct one - #1. The Inc Value is always $01 or $FF depending on the direction. I assume this is not correct behaviour? Two questions - do I have to wire anything different since I’m only using one IC? I do have the 10k on pin 10. Do I need to change any of the code since my encoders are detented?
Thanks for any help..
Justin
inc value is 0x01 or 0xFF (1 or -1 :wink: ), so I think it’s correct!
