Help! OPL Board difficulties
I’ve got a problem with my new opl3 module.
In fact it works, but I get a strange, distorted sound (sounds as if the gain was too high). I got only one YAC512 stuffed, and both channels sound the same.
I checked and double checked for short circuits - nothing found. I changed the TL074 chips - no effect.
What can I do? Any hints welcome.
regards, tom
Hi Tom,
could it be that you forgot the 22k feedback resistors at IC6 (R6/R9/R12/R15).
If this isn’t the reason, check the audio signal before the output amplifier (e.g., at pin 8 and 14 of IC3) - just connect it directly with your soundcard/mixer input (don’t forget the ground connection)
