I have just got a new PIC (remember, I put one in the wrong way and thought it was killed) and programmed it with IC-Prog with the Midimerger1.04.hex file. ICprog says device programmed ok with verify after each step and after programming on.
I still dont get any sign of life out of the merger! I built it on a prototyping board (didn’t seem efficient to make a board for that simple thing) and double and triple checked everything.
Questions:
a) does the midi-merger send out anything after bootup, or is it completely quiet until it receives input?
b) what checks (measurements) can be done with a multimeter other than checking the supply voltage?
c) I connected the “plus” side of the midi-outs of the other devices to the 220Ohm resistor connected with pin2 of the optocoupler and the “signal”-side with pin3 of the coupler, is that correct?
What else can I check?
Is there a simple programI could flash into the pic that just sends out messages to check wehter the PIC is alive?
put the PIC18F… from my Midio128 (with the midio128 program loaded) into the midi-merger to see what happens, and it produces some output, so the quarz is working and the midi-out is wired correctly.
with the PIC18F… in the Midio128 board, put LEDs across the midi-ins of the merger and yes, they are flickering both when the keyboard midi-encoder is active and when the midio128 sends messages, so the midi-ins are also correctly wired.
So what else remains:
a) Can programming the pic (16F…) fail in such a way that icprog reports verified code but the PIC is not correctly programmed?
b) Is there a bug in the Midimerger hex file (latest version from www.ucapps.de)?
In addition to the midimerger-hex file, is there anything else I need for programming the merger?
thanks for your input, but its not the problem. I use the 20MHz quarz for the PIC16 in the midimerger (and of course 10Mhz for the midio128 with the PIC18), but funny enough the PIC18 also runs with the 20MHz quarz (I did that just for checking the correct wiring of midi-out).
thanks for the link with the test programs! I could verify correct working of the output quickly, but the Testrxtx failed. After a lot of measunreing and trying I finally found out that both oprocouplers were killed by my previously inserting the PIC the wrong way (which the PIC survived)!
(I could verify by using the optocoupler from the midio128).
SInce I am merging signals from inside the same “box” (a midified organ) I decided to not use optocouplers and just bridged pin 3 and 6.
From what I have read I understood that optos are pretty sensitive - at least to reversed polarity input. But it’s strange that PIC survives and optos die. (Pic had it’s supply lines reversed - but optos were connected to same pins they connect in normal operation, just in mirror)
Yeah - I have been repeatedly amazed at the toughness of my PIC’s. I’d mention some of the things I’ve done, but I’d probably get banned from the forum for mistreatment.
I thought a bit more about what might have happened. My assumption:
The PIC must have protection diodes on its input pins. When inserted the wrong way, these were connected to +5V instead to ground, so the protection diodes and the darlingtons of the optocoupler were connected in series between +5V and ground without any resistor. The first input signal then openend the darlington and the weaker element (fortunately the cheaper one ;)) burned through.
ANyone knows if the PIC really has protection diodes? I can’t really come up with any other idea why the optos burned through.
