So I need to buy a core module, and the DIN module?
I think I’ll order the DOUT and AIN as well in case I ever decide to use them.
Do I need the PIC programmed with the bootstrap loader - it appears that I do. Also what should I put in the PIC header ID field when ordering? I don’t know what this means.
If someone wiser could help me out it would be appreciated.
What application you need depends on what you want. If you just want to send Note ON/OFF MIDIO128 is the simplest aplication you can use. But as all the application use the same hardware modules, you could change to MB64 later.
Yes thats the simplest setup to midify your laser harp.
If you have no PIC programmer, order it with already burned bootloader.
