hi.. i know the topic doesn’t quite explain what the problem is, but the fact is that i don’t know what the problem is either
i made a test setup of my sequencer, with 2 lcd’s 1 din and ofcourse a core.. everything worked alright, so i decided it was time to mount everything in a case (in my case, mount the buttons/lcd’s/encoders on top of a sheet of metal and screw the rest of the boards underneath it, untill i had a proper case)
so i did, and after a few days of hard work it’s done, but now my setup doesn’t show any signs of life!
there’s not even a midi message on startup, the lcd’s don’t work, nothing.
i am a bit scared that i messed up my pic in the process of mounting everything.. could this be? i probably have some shorts here and there (on the interconnections between boards/lcds, not on the boards themselves), but can that result in a pic not putting out *anything* on powerup?
also i’d like to measure some voltages on the boards, but i’m scared i might mess up things even more by accidentally short-circuiting things.
at what points will i measure voltages on the core to see if my pic is still alive? could it be that it’s not my pic that’s causing this behaviour?
Sometimes they will act this way if you are using an AC power pack and a metal/non-isolated jack to connect it. More info about your power supply please!
i found out the cause of the problem: on the non-working board, i mounted the shiftregisters in the sockets the other way around.
i got sent 2 brands of registers, one with the little ‘dot’ on one side, and one with the little dot on the other side.. i got mixed up.. so stupid to find out it is something so small after a full day of cursing at your non-working setup
it’s working now, except for 1 din, the last one. i know it should be something in the way i hooked up to the ‘second’ one in the row, or with the shift registers. is it necessary to remove unused shiftregisters? or perhaps should i connect certain unused pins to ground?
is it necessary to ground encoders and buttons to the board they are actually connected to? so for instance, i have encoders of step 1-12 connected to DIN2, and 13-16 to DIN3, will i need to connect the ground of steps 13-16 to the DIN3 board? if i’m informed right this doesn’t matter, but maybe it does?
a little addition to the problem: when i turn the step 16 encoder, the second lcd displays a bunch of ‘new’ notes. it’s quite unexplainable. also the note changes, for some strange reason, while the others don’t respond at all. any idea what this could mean?
also, totally off topic; moxi.. would you mind if i email or message you regarding your ‘fabrication de boutons’? i’m quite interested in how you did it.
alright then.. i’ll drop you a line as soon as i find out wtf is causing that last din to not-work.
if i hook up the problematic din directly to the core (leaving the other 2 out of the chain) it is working.. so there must be a problem with the connection between 2 of the din’s. where do i look?
