Help!! MIDIbox64 Problem
Hi:
After a lot of work I finished my MIDIbox64 with 32 pots and 28 buttons.
After solve a lot of wiring problems I get it to work (outside the case).
Now I finished the case and mounted all inside but when I power up
I get this 2 messages “Loading BANK from Bankstick” … “Formating Bankstick” very quick a lot of times, then MIOS restart, and the same
messages again, but this time the app hungs up after some time.
I disconnected the bankstick, and the same happens, I disconected
everything and no change. I uploaded MIDIbox64 2.4 again and no
luck.
Any Ideas.
Thank you.
except LCD
Problem Solved !!!
A not so good solder that brokes when I mounted the PCB in the case.
Thanks
I like this kind of problems  ;D
Hi Sebo,
just for the record: which broken solder joint (where in the circuit) caused that specific behavior?
Best regards, ilmenator
I have a SmashTV Core R4C. The problem was in one of the resistors
under the PIC, I’m not shure right now wich was (the box is closed, and
I don’t want to open it again), but I think is was R2.
Hope this help somebody in the future.
