Hi everyone!
I am a complete noob and I have just build my first MidBox SID (just the Core and the SID modules, without a LCD). Unfortunately I am not able to produce any sound! Could you please help me?
Below are some tests/information of what I am getting while trying to debug the MidiBox:
- In MIOS Studio 2.4.6, I get the following message ( so I think that I covered the “basics”):
Operating System: MIOS8
Board: MBHP_CORE or similar
Core Family: PIC18F
Bootloader is up & running!
- When I run the "mbsid interconnection test v2"application, I can confirm that all SID pins are set to the correct voltage, with the exception of pin “RES#” (always at 0V).
- When I run the “setup_6581.hex” I receive the sysex message “f0 00 00 7e 40 00 01 f7” every 4 or 5 seconds together with a weak high pitched sound followed by silence. However, when I play my MIDI keyboard, no sound is produced.
Unfortunately, I have no idea of any additional test that I could perform. If you could give me any hint or tip it would be highly appreciated!
