Hy, Im very newbie, so I need help. I want to build a simple MIDI controller…(16 or 32 fader thats all…only for my logic:)
So can anybody help me? (Step by step instructions pls…![]()
Thanks.
Snaper from Hungary.
Thanks.
hi snaper
welcome!!!
i am giving you the first steps
1 read properly the pages about MIDIbox64 and MIDIbox64e and the wiki, they are really well written
2 try to figure out what you want to build and draw a schematic, i use to start from the front panel for example so i know how many encoders, faders buttons if i want light etc
3 when you have a (+ or -) clear idea come back to this thread and we can help you to find out which modules and how many of them you need.You will probably get also some good tips about how to improve your design.Let us know also if you consider etching PCB by yourself or want to buy premade PCB with all the components
good luck and welcome aboard
simone
Thank you!!!
So I dont want a big controller…You know I use Logic 7 on Mac and i need a controller for them. I need 32 faders (not motorized) for volumes, (and 64 buttons (32 solo, and 32 mute)), I dont need LCD display, LED rings, etc (extras:)). I need this controller only for the mastering process…bebcause the softEQ-s use I withs mouse like the send effects and etc, but the volumes I heat change with mose. So a imple volume controller for Logic what I need…
And sorry, but I speak not so good english:(
So…you know…first I want to build some easy, and small…like this “volume controller” or a simple transport controller…without LCD disply, start, stop, fw,rw, rec, pause buttons only…
Hey snaper welcome to the board ![]()
I understand English is not your first language, but typing in caps is considered screaming in pretty much every language
This forum is full of people playing with live electricity, so maybe you should save your screaming until you’re getting electrocuted :o
I took time out of my day off sick to check this post because you had me worried for your safety!
Anyway I hope your midibox is a huge success
For a simple project with some transport control, maybe you could consider the clockbox project. It has an LCD, but you will probably need an LCD for debugging anyway.
Thanks, I check this one (CLOCKBOX)…
So I have upload a pictura about what I want to build…a simple controller:) Im from Hungary, can I buy the MODULES in Hungary? Or only from the http://www.avishowtech.com ?
Here is it…
hi snaper
the projects that you re lloking for is the MB64 because it supports analog pots/faders and has a lot of features for them
english is not my language either so don t worry about language just be nice patient never pretend etc etc
for 32 pots/faders you need an AIN4
of course you need 1 CORE module
you ll need a 6 to 9 volts transformers (minimum 0,5 A)
for 32 buttons you ll need a DIN4
1 more DIN2 to connect the jog wheel and transport buttons
that s really a basic you ll need much more stuff: a convenient box, tools, etc don t worry you ll figure out yourself: i advice you to start writing down all these things so if you order anything from a shop you will have to do it only once
a question: what is the display on your design? a LCD to control parameter or just a tranport controller?
At the beginning of this section of the forum you will find a nice step to step guide >>> read it all //
please let us know if you have any experience in electronics, there is no discrimination here about that but communication will be easier if i know what you can do what you will learn to do ![]()
about the modules and where to buy it: there is a german guy who sells pre etched pcb and all the components here: http://www.mikes-elektronikseite.de/
best
simone
So…I make this “design” in a paintbrush clone ![]()
(16faders,32pots (16for panorama, 16 for send 1), lcd for transport (rec,start,stop,fw,rw,pause buttons), and a jog.
Thats all.
(Are you from Germany?)
(Cause Im from Hungary…I send you a PM)
The first problem…:
I go the shop, to buy faders…and…i dont know..STEREO OR MONO FADERS:))))))) Jesus I tell him I need this faders to a MIDI controller…but…
Mono, cause you only need one channel for the AIN.
Thanks…so next questions :
1 : Ohms for potmeters and buttons? (16 fader, 16pot, 32button…)
2 : Which button need I…the “TICK” and its on…“TICK” and its off, or the “TICKTICK” and its on…“TICKTICK” and its off…----->for MUTE/SOLO
You can use a wide range of pot values, but most commonly used is 10Kohm. Buttons have no resistance value, but you want momentary, normally open switches. These are the kind where
Thanks…we working on the core modul…(me and my firend)![]()
So…![]()
How to connect 32 buttons to the DINX4 modul?
Casue’ I download the connection diagramm, but I see in this diagramm : I can connect only #24 buttons and 8 others…others are the bank select buttons?
quote from http://www.ucapps.de/mbhp_din.html :
How to connect 32 buttons: http://www.ucapps.de/mbhp/mbhp_dinx4_32buttons.pdf
If you are interested in a particular answer to a question, you should first read the most obvious relevant pages @uCApps.de, at least the one of the module you’re asking about ;) ![]()
Cheers,
AC
OK, thanks, bu you know…yeah but what are the 8 others? (not the sidned #1-#24)
And another problem…the MIOS upload…so I download the Java applet and start it under OS X 10.4.8 Tiger…and in start I see a picture aboout many-many MIDIbox-ses, but thats all…no menu, no windows, nothing…whats the matter? (And yeah, I go to the SUN homepage but I cant find the runtime environment for OS X…only for win, linux, solaris)
hi snaper
follow this link and read ALL of the posts in the first 2 threads
about adapting your MB to your needs and design i advice you to download MB64 application and open the files main.asm and mios_table.inc : it s a good start to understand the application and the parameters and value you will need to adjust.
simone
snaper you also want to read the first 2 topics on this forum section about MB64 and the LC protocol.
simone
