Help! I Need some suggestions
Hello,
I’m trying to build a MIDIbox SID. I already assembled the Core and the SID modules.
The core seems to comunicate through MIDI ports with MIDIOX, so I update MIOS_v1_8 and
I load MIDIBOX SID_v1_7a.
And now the problems start.
  1. The LCD doesn’t show anything. To be more precise: the back lite is on but it is not possible to read anything.
I checked the connection between LC and Core module and everything seems OK!
Since I’m tryng to use a 4*20 LCD I changed main.asm file for 2*40 LCD. Is it correct?
With MIDI-OX I sent        F0 00 00 7E 40 00 0D 02 00 0B 0A 00 00 00 01 00 00 00 00 F7
and MIDI-OX received    F0 00 00 7E 40 00 0F 04 00 F7
I expecetd to receive      F0 00 00 7E 40 00 0F 00 02 F7
Where is the problem?
  1. SID MODULE: no sound only a small noise that could due to a bad 50Hz filter.
I run the interconnection test and everything is fine.
I’m using the C64 PSU modified (but not optimized)
Which other test can i do to solve the problem?
Any suggestion is welcome
Ciao
Antonio
hi,
just to be sure, did you adjust the trimpot for lcd-contrast on the core module?
i dont know if this is possible
cheers, marcel
Hurrah!!!
my SID is working  and my LCD is displayng the following characters:
A 1    C 1    1 ------------
Internal Patch.
Is it ok???
The MIDI SID  is working but after a while of nice sound there was a reduction of volume and an increase of noise.
I don’t know what happened. Maybe something too hot, maybe some bad connection, maybe…
Is there anyone that want to suggest me something?
Regards
Antonio
Be shure that all capacitors are stuffed in the right way, perhapse this will solve your problem…
… just an idea :smiley:
greets,
pwx
Thanks!
Another problem could be some bad connection!
Tomorrow i will check!
What about the display?
It shows the following message:
Internal Patch.
Is it correct?
Yes, thats correct
It will change, once you press the exec button
