Hi folks,
I’m using EAGLE light V 4.06 and try to open the above
mention file. I got always an error “Error reading …”
Any suggestion?
All hints and advices are welcome.
Greetings Roman
Hi folks,
Any suggestion?
Greetings Roman
Hi folks,
Any suggestion?
Greetings Roman
Hi..
First off, the most recent version of eagle is 4.09r2 - not sure of the updates but u may wanna get it…
To open the .brd files goto:
File > Open and select ‘board’ from the list of filetype options. Then direct the browser to the mhbp_core_v2.brd file.
Best…
Hi..
Best…
thanks for your help, but it is the normal way I used
to open a file in EAGLE. It shouldn’t be that, without
major number changed, there is a different file format.
Roman
Roman
I created the layouts with the Linux version of Eagle. Don’t know if they are incompatible, but normaly - with the most up-to-date release - it should work.
Hi folks,
thank you for all answer received yet. Unfortunately
it’s don’t work. I loaded down the lastest release of
EAGLE light 4.09r, but the error comes up furtherwise.
Roman
P.S.: I also have get an blank page if I tried to reply
to this topic. After I delete all files in the cache I
were able to wrote this lines?
Hi folks,
Roman
Hi folks,
the problem is solved. A user of EAGLE tested the file
and send me the CRC (3E8EDFB7). After this I#ve seen
that my Computer convert automaticly the LINUX file
to WIN (add 0x0D to 0x0A = 0x0D0A). Now I’m able to print
out the board.
Greetings and a happy new Year to all
Roman
Hi folks,
out the board.
Roman
