Heeeeeeeeelp!!!
hey guys
please, excuse me for starting a new topic on this same issue i’m having
some weeks ago, i posted a problem i had, having an incorrect resolution with 24 step encoders
this is the only thing i’m missing for having the sequencer complete
i have tried all kind of things
i open MIDIbox64 SEQ.mcp project file within MPLAB
before that, i edited the mios_tables.inc
changed the ENC_ENTRY settings to
MIOS_ENC_MODE_DETENTED2
aswell as changed same entries in the setup_mbseq_v2.asm file
then i run “Make”
it makes me the hex file
then i use Perl to convert it to syx file
i upload it to the SEQ, start it up
encoder resolution is still incorrect ..
1 step on the encoder , makes 2 steps on the display, sometimes even more steps ..
sometimes it will even jump a whole octave..
ok,
then i try setting the ENC_ENTRY’s  to MIOS_ENC_MODE_DETENTED    without the “2”
same result .. absolutelly nothing happens
i even tried using  MIOS_ENC_MODE_NON_DETENTED
same thing
this is so desperating
this way it is very difficult to set the note i want it to play
does anyone has any kind of advice ?
maybe there is some kind of “speed” setting for encoders or something like that ?
am i doing something wrong ?
i even tried starting a new project in MPLAB, and loading setup_mbseq_v2.asm, make the changes ..
same results
please, i seek any kind of advice or knowledge on this
i will greatly appreciate any kind of reply
cheers
hey guys
then i run “Make”
ok,
same thing
same results
cheers
Hi
I have used the following:
cs_menu.inc: the CS_MENU_EncSpeedSet function allows you to totally customize the encoder behaviour for the menu encoder
pEaCe
Hi
pEaCe
