See bottom of the wiki page: http://www.midibox.org/dokuwiki/wilba_mb_6582
What’s the purpose of the J70 header?
This is a passive mixed output of the four stereo channels, which you can connect to the small phono jack above the power switch. Totally optional.
This was a late design idea I threw into the prototype, the resistors below each audio socket are used to connect the audio signals together when there is no plug in the switched audio socket, i.e. it will only mix those sockets without plugs. You need to connect it together with insulated wire under the board though…. I didn’t want to mess up the ground plane with tracks. To the right of the resistors R70-R77 (below the stereo sockets) are pads, these pads should be connected in two sets of wires, one set connects the pads that are next to R70, R72, R74, R76, the other set connects the pads that are next to R71, R73, R75, R77. (NOTE: R2 boards do not require the wires, there are tracks on the top layer.)
I used 10K resistors there because that’s what I’ve seen before in passive mixer designs, but the output is very attenuated, and I am guessing that you could drop these to 1K or less, as the outputs of the audio buffers after each SID can probably handle that. Someone with more audio electronics (and SID!) knowledge can probably answer that question.
I just added that you don’t need the wires with R2 boards. Do you have an R1 or R2 board? i.e. did you get the board from me or from SmashTV?
Note that you will NOT get the mixed audio if you are NOT using switched stereo sockets, because the audio only gets mixed for channels which do not have a plug in the socket.
So maybe you have plugs in those sockets, or you didn’t use switched stereo sockets.
Or alternatively, you didn’t add the resistors R72-R77 (near the audio sockets)… R70,R71 must be there or you wouldn’t get SID 1 output.
Or alternatively, you have an R1 board and didn’t add the wires… if so, look at the PDF of the R2 board and add wires to match the top layer tracks that connect one end of each of R70-R77
