Just discovered the MIDIbox & this site today: YIKES! I had no idea! An open source style DIY hardware MIDI project: how cool is that! And the PCBs can be ordered pre made!!! I’m psyched!
Here’s what I’d loOoOove to make:
A hardware programmer for the Yamaha TX81z FM synth (single mode, not multi) should have:
bank of 8 motorfaders, buttons to switch their function (faders jump accordingly) Display to indicate current fader function above each fader, name of fader bank, fader values, etc.
facility to “load” a patch from the 81z via sysex (i.e. request the patch & reassign all the faders to match the loaded parameters so you can start editing) facility to save/name patch optional (could be done from 81z front panel instead)
Midi merge so you can drive the 81z from a sequencer while you tweak it…
um, is this something that is doable? Could it be expanded into a generic editor for other synths (CZ-101 anyone?) Kind of a PC-1600 with motorfaders organized into ‘presets’ for different synths w/ banks of faders.
I’m still digesting all I’ve read, so not sure how all the pieces fit together.
Incidentally, I got here by doing a google search after getting samples of some Maxim ADCs & wondering if I could use them w/ a basic stamp to make an 81z editor.
My only controller projects so far are 2 basic stamp based custom talkback logics for radio applications (one works w/ yamaha DM-2000, another with 01v) that lets you address different busses w/ the talkback while dimming the monitors (all via MIDI sysex ) so you don’t send the program down the line. This worked well & I even managed to use illuminated momentary switches for postitive feedback.
Just discovered the MIDIbox & this site today: YIKES! Â I had no idea! Â An open source style DIY hardware MIDI project: how cool is that! Â And the PCBs can be ordered pre made!!! Â I’m psyched!
Yes, i think all of this is possible with MIOS. I wanted the same interaction of encoders beneath my display and was told it was possible
facility to “load” a patch from the 81z via sysex (i.e. request the patch & reassign all the faders to match the loaded parameters so you can start editing) Â facility to save/name patch optional (could be done from 81z front panel instead)
Yes, this should be possible. There are standard functions in MIOS which allow loading and saving.
This is a standard option in MIOS, so don’t worry about this one.
um, is this something that is doable? Â Could it be expanded into a generic editor for other synths (CZ-101 anyone?) Â Kind of a PC-1600 with motorfaders organized into ‘presets’ for different synths w/ banks of faders.
You can save/load multiple setups in/from a bankstick. (but just 1 can be used at the same time) And if i remember correctly, up to 8 banksticks can be used.
Be forewarned: The TX81Z sometimes stutters if you send it a lot of continuous sys-ex while it’s playing. Also some parameters (like operator frequency) can be tweaked while a note is sounding, but you won’t hear the results until the next note plays. This could be a little weird if you are trying to tweak, say, a really busy bass line.
The other thing: with motor faders, your controller will probably cost more than your TX81Z is worth!!! May I suggest you consider rotary encoders, optionally with LED rings.
yes, i’ve noticed this w/ Unisyn & a Cubase mixer map I made once. Mostly I’d like to make this for coming up w/ new sounds w/out having to mess around w/ a patch editor on a PC or using the built in UI.
yeah, that is true, but think how much more valuable the 81z is w/ hardware programmer! I think the faders would be worth it if I could use the same box for other purposes w/ ease. If it’s just a dedicated TX81z editor, then probably LED rings w/ encoders or even pots in ‘hook’ mode would be more practical.
any suggestions on what I’d need to do this? For the moto-fader option it sounds like I need to build:
core moudule
MF module
AIN module
not sure what else…
but what about for pots or encoders w/ led rings? guess i should pour over the website for a few more hours tonight ;)
