Been a MIDIbox user for a few years now (thanks, TK!) but this is the first time I’ve not found my question already answered somewhere.
Having been on MIOS8 for so long, I recently got an STM32F4 Discovery to start work on replacing my existing board. It was all going really well until I tried add an RTOS task with (I presume) not enough stack memory allocated, resulting in a “hard fault at PC=0x00000000”.
I’ve amended my code to allocate a bigger stack, but now I seem to have no way to upload any more. The error condition occurs very soon after bootup (in App_Init()), but using the reset button on the Discovery board doesn’t seem to trigger an upload request - MIOS Studio doesn’t respond in any case. I’m guessing my config must have fastboot turned on.
Ah, just realised that I didn’t actually need to make a first post - I’ve just this moment seen the bit on that page I linked to that mentions using the User and Reset buttons to force bootloader mode… and it works a treat!
This reminds me, that I wanted to implement a fallback mode, so that USB MIDI access is still possible, and also some terminal commands for debugging are available (e.g. to dump a memory map for stack analysis)
Whilst I can now recover the board after a crash, I am still getting these “hard fault at PC=0x00000000” errors whenever I try and create an RTOS task.
Running umm_info() before attempting to launch the task gives this:
[24733.110] Total Entries 0 Used Entries 0 Free Entries 0
[24733.110] Total Blocks 2048 Used Blocks 0 Free Blocks 2048
[24733.110] Size of umm_heap is 24576 bytes, used: 0 bytes, free: 24576 bytes
I have fiddled with the values of the stack size in the task creation and the only extra information I have been able to ascertain is that if I request too much memory, or none at all, then there is no crash (but nothing useful happens either), which seems to indicate that the crash is only happening when there *is* available memory.
e.g.
xTaskCreate(TASK_LED_Update, (signed portCHAR *)“LED”, 4*1536, NULL, PRIORITY_TASK_LED_UPDATE, NULL); gives the error in MIOS Studio console:
as you can see, the byte size has to be divided by 4, because FreeRTOS counts the memory word-wise
Which means, that you tried to allocate 24580 bytes - which fails (for obvious reasons).
Note that programming_models/traditional/main.c creates two additional tasks for MIDI and other purposes, which need memory from the heap as well (1024 bytes per task as defined with MIOS32_MINIMAL_STACK_SIZE)
