If other displays work, then it’s the display or cable, a short between the pins on the display, or a bad connection on the IDC plug maybe… but then it could also be a break on a track of the display itself, which is probably unfixable… your instincts are right tho… try a test app that prints ASCII 65 to whatever… look for a pattern.
Or it could be broken rom/ram on the LCD itself. as the other chars printed are just a random mess…
Ill try to find a suitable replacement 2x24 but the drill holes dimensions must be the same sigh.
