Half Potty
Folks,
I am posting this in the hope that some of you have come across thic problem. When I connect my AIN to Core and load up my MIOS, only the second half of the pots of each gang of eight work! So, in my example, the first four don’t work, the second four do, the third four don’t wotk the third four do. And anything after that just doesn’t work.
I’ve tested all the wiring by checking the voltage between the ground of the core and the pin that corresponds to each pot on the respective 4021 on the AIN, and the voltage is spot on. (5.3v)
I am going to reboot the MIOS next, but am baffles. Has anyone come accross this before?
Thanks All,
MP
Maybe look at the address line cable and connections (J6)? Is it a custom app?
Yes. You have already helped me with grasping the programming on another section of the forum. It’s the B4 controller I built from old VOX parts.
Once again, I am indebted to you…
MP
Oh Oh,
Think I’m in big trouble. Tried to reload the MIOS onto the PIC. Is there a reason that O should not have done this. Tried it over MIDI!!
Help… ???
Panic Over.
Just clicked don’t use message from core in MIOS studio.
Phew. :smiley:
