Group Select Indication - with LEDs?
Sorry if this is a stupid question…
I want to show Group Select of my encoders with LEDs’ (using a DOUT right)?  Can I do this or do I have to use the LCD display?
It seems obvious that I can use this:
[bUTTONS]
    1.1  =  FF 01 00  # switch to Group #x.1  –  for quick bank access
    1.2  =  FF 01 01  # switch to Group #x.2  –  for quick bank access
for the buttons, but how do I assign the LEDs so that ***only*** the LED for the selected group lights up and the others are turned off?
you can do this by mapping the group number to the LEDs:
# LED Map: assignes the LED shift registers to the Button Shift
# registers or special values
# Currently following values are supported:
#    0    Default Setting (see Map below)
#    1    Button Shift Register 1 (Button ID #1-#8)
#    2    Button Shift Register 2 (Button ID #9-#16)
#    3    Button Shift Register 3 (F1-F4 and Navigation Buttons: ID #17-#24)
#    4    Button Shift Register 4 (Button ID #25-#32)
#    5    Button Shift Register 5 (Button ID #33-#40)
#    6    Button Shift Register 6 (Button ID #41-#48)
#    7    Button Shift Register 7 (Button ID #49-#56)
#    8    Button Shift Register 8 (Button ID #57-#64)
#    9    Selected Group (1 of 8)
#  10    Selected Bank (1 of 8)
#  11-15  reserved
#  16    MIDI Status received for Button ID #1-#8
#  17    MIDI Status received for Button ID #9-#16
#  18    MIDI Status received for Button ID #17-#24
#  19    MIDI Status received for Button ID #25-#32
#  20    MIDI Status received for Button ID #33-#40
#  21    MIDI Status received for Button ID #41-#48
#  22    MIDI Status received for Button ID #49-#56
#  23    MIDI Status received for Button ID #57-#64
#  24-31  reserved
[/code]
So, assignment option #9 is for what you are searching for
very cool - thanks  ;D
