Hi all
Firstly thanks to TK and everyone involved with this superb project. Now to the begging stage… ;D
The Core module seems to work OK (MIOS 1.8 uploaded) and is showing loads of random controller and note events which I take is normal when the analog inputs aren’t clamped to ground.
Problem is when plugging in the LCD, the PIC appears to continuously reset. Am pretty sure the LCD is wired correctly as the 16x2 I’m using has the pins clearly marked and I managed to pull a datasheet for it off the web. (Vikay 2322) I tried another LCD but am experiencing the same issue. Am assuming there has to be a fault somewhere on the core module but for the life of me cannot figure out what it could be. The PIC is a 18F452 as sold by Mike’s. Bridge 6 is wired between pin 28 and J4’s SC pin.
When plugged in the LCD shows a row of black bars in the first line.
Breakdown of MIDI msgs are as follows:
(a) LCD not plugged in
0008A1B1 1 – BD 4A 42 14 — CC: Brightness
0008A1B2 1 – BE 4A 41 15 — CC: Brightness
0008A1B3 1 – BF 4A 42 16 — CC: Brightness
0008A1B5 1 – B0 07 42 1 — CC: Volume
0008A1B6 1 – B1 07 42 2 — CC: Volume
0008A1B7 1 – B2 07 42 3 — CC: Volume
0008A1B8 1 – B3 07 43 4 — CC: Volume
0008A1B8 1 – B5 07 41 6 — CC: Volume
0008A1B9 1 – BC 07 40 13 — CC: Volume
(b) LCD plugged in
0008E188 1 – FF – – – — System Reset
0008E7F6 1 – FF – – – — System Reset
0008EE65 1 – FF – – – — System Reset
0008F19D 1 – FF – – – — System Reset
0008F4D3 1 – FF – – – — System Reset
0008F80B 1 – FF – – – — System Reset
0008FB2F 1 – FF – – – — System Reset
0008FB42 1 – FF – – – — System Reset
