I recently bought some GM5 boards to make 2 units for my PC, one board with 10 MIDI in and one board with 10 MIDI outs.
I bought the little PCB’s and I want to create the breakout board. But I had a few little questions about that:
The only LED that is on the GM5 PCB is this the USB status LED?
Does anyone has a simple schematic for led drivers so I can connect a LED to each midi port? I wanted to know this things before I order the front panels. I just finished the design.
Curious about the comments…
Thanks!
Best regards
Hans
PS I’m also working on a MIDI router, which will be posted soon, and a MBLC. I hope that I can tell you more about them soon.
The midibox LTC has a LED driver on it so you can check out that schem at ucapps.de. What I did in the gm5x5x5 was to simply use an inverter (74HC14) to buffer the signal and the (the schem for that is linked to from a thread in the forum, search for “midi splitter”).
Thanks for the reply! Sorry about the stupid question, it was quite logic that the LTC module contained a nice and clear LED buffer.
So only the last question remains, (I hope I don’t start to get on your nervs…) is the only LED on the GM5 PCB monitoring the USB status? (just to be sure, so I can order the panels at schaeffer)
