Getting Bankstick Data via SysEX
Hi Mates,
long time no see (though I’m still tracking and trying to keep updated)… I was very busy the past year, but I’m now having again a little bit more time to spend on my midibox stuff :slight_smile:
I’m currently trying to code a patchmanager for the ACSensorizer (lost track of what is stored there), but I’m having troubles getting the BankStick data via SysEx for any other bankstick than the first one. I read mios_syses_implementation.txt over and over, and even tried the deprecated bankstick select command, though with the same result:
This is working for the Bankstick #1:
[tt]  F0 00 00 7E 40 00 01 40 00 20 00 F7[/tt]
and I get the whole bs data in return, all data okay
But when I try to get the contents of the second Bankstick:
[tt]  F0 00 00 7E 40 00 02 40 00 20 00 F7[/tt]
I get the error:
[tt]  F0 00 00 7E 40 00 0E 01  60 F7[/tt]
wich means: 0x01      | Less bytes than expected have been received
Now I’m slowly going to tear my few remaining hairs out, 'cause I’m trying for two days now and I can’t find any explanation for this behaviour  ???
Any hint for me?
Cheers,
Michael
It should work with 11 instead of 02
See also mios_backup.txt
   o if additional BankSticks are connected, do the same like above,
     but change the BankStick ID (1-7) like shown here:
                          +--- BankStick ID
        F0 00 00 7E 40 00 11 40 00 20 00 F7
        F0 00 00 7E 40 00 21 40 00 20 00 F7
        F0 00 00 7E 40 00 31 40 00 20 00 F7
        F0 00 00 7E 40 00 41 40 00 20 00 F7
        F0 00 00 7E 40 00 51 40 00 20 00 F7
        F0 00 00 7E 40 00 61 40 00 20 00 F7
        F0 00 00 7E 40 00 71 40 00 20 00 F7
     For 64k BankSticks use:
        F0 00 00 7E 40 00 01 40 00 40 00 F7
        F0 00 00 7E 40 00 11 40 00 40 00 F7
        F0 00 00 7E 40 00 21 40 00 40 00 F7
        F0 00 00 7E 40 00 31 40 00 40 00 F7
        F0 00 00 7E 40 00 41 40 00 40 00 F7
        F0 00 00 7E 40 00 51 40 00 40 00 F7
        F0 00 00 7E 40 00 61 40 00 40 00 F7
        F0 00 00 7E 40 00 71 40 00 40 00 F7
[/code]
> Now I'm slowly going to tear my few remaining hairs out
Time to change your avatar (Homer Simpson? ;))
:d’oh:
thanks so much :slight_smile:
luckily I still have more than three hairs left due to your quick help =)
(I think I can safely stick to that Avatar a couple of days)
Best regards,
Michael
ps:
in case anyone doesn’t know the simpsonzier yet
http://www.prosieben.de/spielfilm_serie/simpsons/simpsonizer/simpsonizer.htm
