Hi
Does anybody know if there is any way of converting *.fpd to *.dxf?
Thanks
Dimitris
Hi
Thanks
Dimitris
Hey…
I tend to print to a PDF (keep everthing vectorised) then open in ie, Illustrator retrace quickly (smart guides ;p) then export to dxf or whatever…
Best
Thanks d2k!!
Very fast reply - I thought the conversion was not possible without the schaefer plug-in.
I should also say congratulations on your projects - I am currently building a 4xSID CS synth (1 core + 1 sid ready as of today - what a sound!!).
Best regards
Dimitris
mebbe so but I have acrobat - so can file>print to PDF instead of a regular printer ![]()
I think there are free/shareware distillers about that do this too…if not just send me the .fpd and i’ll pdf it.
thanks
and ye the SIDs are tasty indeed!
Thanks again!!
I happen to have acrobat too, so things have become easy for me :D- although I am not sure yet if I must have my panel made somewhere or if I should make the drilling myself. I would definitely do it if the problem wasn’ t the square hole for the 2x20 lcd. Also another question is how many more holes compare th the initial TK’s design (in *.fpd) should be included in the panel :-/, since I saw that chriss’ 4xSID has some more buttons (selection for non- linear envelopes and sync - probably the addition that were made in MIDIBOX SID 1.6 (I am posting another message for that in the design section)
All the best ![]()
