so i think i’ve tried everything, but i am recieving no sign of life from my core.
i just checked my midi connections with a loopback, and it seems to be working just fine.
so, i’ve come to the conclusion that i’ve fried my core chip. it’s sitting on a bread board right now, and im trying to figure out the most basic setup for it to test it’s midi i/o.
i’m thinking connected pins: 1, 11, 12, 13, 14, 25,26, 31, 31 back to the core would be a proper way to isolate what i’m looking for, or should i run out to radio shack and pick up the basic parts i need, or is this more trouble than its worth?
so i’m not sure what i did, but the PIC is working now.
it was up on a breadboard and i attempted to load mios again and i got a response with midi-ox.
i switched over to MIOS Studio and re-uploaded MIOS again, studio said everything was good.
now, i’m not quite sure of the proper steps from this point on.
using MiOS Studio, i then sent SID programs; first i sent the one entitled main, then 6581_without_cs (since my sid doesn’t have any sort of cs at the moment).
next i sent some midi commands using the keyboard, but i got no response. i tried changing SID chips (to another 6581) and rewired my connections from core - j10 to sid - j2.
i haven’t tried soldering the wires directly to the jumper spots yet (the only reason i would do this is because i got super glue on the jumpers while building a cable out of old IDE cables).
should i keep messing with my cables, or reload my software differently?
Except for Vs and Vd these are HF waveforms which can only be checked with a scope (the values displayed by your measuring instrument are useless in this case). The connections can be checked with the mbsid_interconnection_test_b
