Well, in my attempts at being overly cautious, yet clumsy, I’m pretty sure I fried my PSU.
I was testing the voltages on the pins of the PSU, thinking I needed to make sure there was no issue with the PSU before hooking it up to my PCB. I think I must of slipped. At one point I heard a tiny little pop, but it was very tiny and I didn’t think anything of it. I suppose it was enough of a pop that I realized I didn’t know what I was doing well enough to try testing the PSU directly, though I thought I had covered all my bases.
I went ahead and tried the PSU with my PCB. Ok, not too smart after what had just happened, but at least the PCB wasn’t hurt. The 5V rail looked fine. The 9V rail barely had a volt or two on it. I hooked the PSU back up on my C64 and sure enough, the power light came on, but it didn’t have the juice to drive video.
*sigh*
I see three options:
My PSU doesn’t seem to have screws, but I could try to crack this thing open and see if it’s a simple fuse replacement (if it was a blown fuse, I shouldn’t get ANYTHING on the 9V rail though, correct?)
Buy a “new” PSU (I’ll be doing this anyway if I want to run my old C64 again
Try to run the entire thing off a 15V PSU using like Altitude explained on
< base_url >/topic/16595-running-mb6582-off-a-single-12v-dc-supply/page view findpost p 146100?do=embed
thread. I like this idea, and was planning on doing it once I got my MB-6582 working w/the C64 PSU. But, since I have no PSU to test with right now I’m not even 100% sure everything is set up correctly on the PSU. (I feel pretty confident that it is… everything that I’ve tested checks out and I’ve double and triple checked my connections)
Any thoughts from ye exalted enlightened ones? It would be much appreciated.
I know I’ve been posting a lot here… please pardon my noob-ulant exuberance.
Thanks,
Blatboy
