Forking Jsynthlib
Is there anyone here who knows enough about Java to join me in forking Jsynthlib?  My intent is to continue development of this utility, fix bugs, add new synths, and generally keep bitrot away.  I have a private server to host a CVS repository.
When I read the topic title, it reminded me of what I say when I use JSynthLib… “Forking JSynthLib!!!” I personally don’t like the interface at all, although the concept is good.
Specifically what bugs you?  Is it something that could be fixed without trashing the entire user interface?  At present, all I want to do is get rid of the cruft.
Probably it’s a collection of little things… the way you manage a patch library and then edit one patch and get it to work in realtime on the synth, it was all a bit unintuitive and in addition I had heaps of problems getting it to work. The actual patch editor GUI (at least for MB-SID V1) is nice. I want to do a MB-SID V2 patch editor but I am thinking adding it to MIOS Studio would be better (at least not have to fight the JSynthLib architecture and bugs).
I only wish I had the time to beef this app up… That is a project I have on my list to do in a year or two, if noone else has it taken care of by then.
If you do take it on then please keep in touch maybe I can help out here and there.
I’ve the same problem: I definitely would like to improve the user interface of JSynthLib, as I also find that the patch management and general workflow requires a lot of improvements. But there are too many other interesting projects I’m doing in parallel…
So, I can only say: count me in as beta tester. I would also give you the required informations for MBSID V2 patch structure and handling of course.
