Hey everyone… I just took a moment to write up the steps I use to clean flux from PCBs after I assemble them. This isn’t always needed, but it’s generally regarded as a good idea.
I do this using simple 99% isopropyl alcohol, distilled water, and a few brushes. That is, chemicals and supplies which are commonly available and not especially expensive.
I use Genesolve 2004, which is so good, it’s acutally illegal to manufacture! But somehow I am able to buy it every year.
Looks to me like it’s just a CFC / Methanol blend. (datasheet) Why not use just methanol (or isopropyl, since it’s easier to obtain) instead of dumping CFCs into the atmosphere? I’d imagine straight alcohol is cheaper, too…
Props man.
Believe me, that hole in the ozone layer, which sits right over Australia, you can feel that in summer…And our weather is changing drastically every year…Dodgy.
Today it was 37.2°C here, with an apparant temp (after figuring in humidity) of 40.5°C. And we’re at ~42.5°N latitude.
Well I used no clean solder and I am very happy with it but I bought some crappy radio shack wick which left some brown stuff on the board when I had to desolder anything. I got some better wick right away but I already made a couple modules while using the radio shack brand. The other boards look fine but still have that clear goo around the joints.
I’ve been using Flux-Off from Chem-spray for cleaning my boards. It’s mediocre at best. It never seems to get all the flux off. Instead it gets spread all over the board and makes it sticky. It sounds like using denatured alcohol would be a better idea. Would it be a Good Idea to submerge the board in alcohol as long as I take care to use washable switches and pots?
Clean your board afterwards with water. (do not solder pots on the board yet and other things that can get rusty when washing in water).
