I’m building an interface to cubase sx. I plan on having 20 channels, each with 2 send level knobs, 1 insert level knob, 1 pan knob, mute, solo, arm and channel select switches with LEDs showing switch status and a volume fader. Therefore for the 20 channels I would require 80 knobs, 80 switches, 80 LEDs and 20 faders. This is to help me with mixing in cubase.
Also to assist in controlling effects parameters I plan on having an effects section. This will have a 5x4 matrix of knobs with 2 faders that control input and out put level. I hope to use this when using compression, reverb, delay, modulation and multiband effects.
The midibox will also have a transport controller with 8 switches, 8 LEDs for showing status of those switches and a knob for scrubbing.
I will include an assignment section with 3 switches for bypassing inserts, sends and eq for the selected channel and 3 switches for automation. Each switch will have an accompanying LED to show status.
The board will also have a zoom section with 5 switches.
The total of controls would then be 100 pots/knobs, 22 faders, 99 switches and 94 LEDs. From what I understand I should be able to achieve this with 2 core modules, 4 DinX4 modules, 4 DoutX modules and 4AinX4 modules.
I wanted to confirm is this is true or am I going wrong with this design? I also wanted to have LED meters for each channel and do not know how I can achieve that since I don’t have enough LEDs left. I’d really appreciate if anyone could guide me on that. Another thing that I wanted to confirm was what other modules would be necessary to add, do I need an LTC module? Should I add the LCD module? How do I make a digit display that shows bars beats and tick/hours minutes and seconds? From the data on the website, I gathered that it is possible to attach 8 motorfaders to one core module, in that case I should have 3 core modules to have 20 channels. Does the motor fader module add 8 faders in addition to the 64 pots that the Ainx4 module provides? If I use normal fader and not motorized ones will my design then be correct with 2 core modules? One last thing, will I need to do any programming besides assigning controls there functions as in assembly level programming of drivers etc?
This website has gotten me damn excited!!! Hats off to the people who maintain and contribute to it!!! I’d really appreciate any kind of help that I can get. I want to have a perfect design on paper before I start the actual build.
