Firmware changes
Hi MidiBoxers!
Is it difficult to edit the MIDIbox SEQ V4 firmware,
to add custom button shortcuts?
Would this be possible for a MIOS32 programming beginner?
Best regards
Marxon
Hola,
imho it has a great & well-documented code base, better than many “commercial” pieces of software i´ve seen - it should be possible to add what you want, if you have some C knowledge and are willing to read a bit into the code.
Many greets,
Peter
http://discourse.midibox.org/t/topic/17477
OK thanks!
Seems like i have to edit seq_ui.c because
i want Menu + Rwd to work as a Copy button shortcut.
My first try:
static s32 SEQ_UI_Button_Rew(s32 depressed)
seq_ui_button_state.REW = depressed ? 0 : 1;
if( depressed ) return -1; // ignore when button depressed
if( seq_ui_button_state.MENU_PRESSED ) ///line added
return SEQ_UI_Button_Copy(depressed); ///line added
if( SEQ_SONG_ActiveGet() ) {
portENTER_CRITICAL();
SEQ_SONG_Rew();
portEXIT_CRITICAL();
} else {
//SEQ_UI_Msg(SEQ_UI_MSG_USER, 1000, “We are not”, “in Song Mode!”);
SEQ_UI_Button_StepViewDec(depressed);
return 0; // no error
But i guess it is not that easy…
Have you tried looking at the config file on the SD card? A LOT of functionality can be changed there, maybe this is already enough for what you want to achieve?
Hi again,
…maybe this is already enough for what you want to achieve?
Unfortunately i can not achieve it only by using the configs…
I played with the firmware code some hours.
It was worth the try but it seems without some C knowledge, i will not get it work.
Now i have two options:
Start to lear C or add some additional buttons…
solving a problem with your brain is most often better than solving it with your hands :smiley:
Ja ja, hast ja Recht :b
Außerdem wäre etwas C Wissen sicherlich auch für andere Sachen nützlich.
Aber der Zeitaufwand… *seufz*
Kannst du eine gute Seite/Ebook empfehlen und mir sagen auf welche “C-Bereiche” ich besonders Wert legen sollte oder ich für MIOS auslassen kann?
mfg
Marxon
http://net.pku.edu.cn/~course/cs101/2008/resource/The_C_Programming_Language.pdf
Kann Dir leider nicht mit guten Tutorials helfen, ist bei mir schon über 20 Jahre her :-D.
Hier gibt es einige Artikel - alles in allem ein Haufen Arbeit, die aber belohnt wird:
http://www.mikrocontroller.net/articles/C
brief in english: difficult question, can´t help you a lot with that, as it has been too long since I started learning it - linked a few german papers.
Ciao,
Peter
Thank both of you for this links!
@EsotericLabs:
Thats something i was looking for.
In the Preface it is written:
"The book is not an introductory programming manual; it assumes some familiarity with basic
programming concepts like variables, assignment statements, loops, and functions."
@Hawkeye:
Your link is good too.
Nice tutorials and downloads.
Thus, the next few weeks are scheduled.
But i am sure you will read from me :wink:
Best regards
Marxon
