Finally tested my Midibox FM
I think you (and other people that gave their advice on the transformer) should take a look again at the link to the PSU kit. I noticed that the website mentions:
Supply voltage: 18V AC / 200mA
It also mentions the use 7812 and 7912 regulators. These regulators need at least a bit more (!) than 12V to do their job (that is: regulating the DC power to keep it around +12V and -12V).
I think that using a 2x12V (this is the same as a 24V center tapped) transformer will not give you enough potential for a stable PSU. I’d rather go for a 2x15V (30V center tapped). If you have a hard time finding this one you could also use a 2x18V transformer but this will result in much more heat on your regulators.
I would also recommend to buy a transformer that can deliver a bit more current than you actually need. This improves the performance of the transfomer.
Greetings,
Rutger
ps. I found this site to be very usefull in PSU design issues:
http://sound.westhost.com/power-supplies.htm
12vac transformers deliver more than enough to drive 7812’s, because the voltage gets multiplied by 1,4 when rectified. I made a +12 / -12 regulated PSU for midibox, just look it up in my WIKI, any and all comments are welcome (in the thread linked in the wiki article please, let’s keep the topics clean :slight_smile: ).
Tilted. it looks like you actually haven’t modifed that picture, and it’s super small.
I did modify it, but the mod itself is minimal.
“all” you need to do is remove the diodes, then connect your bridge rectifier where the diodes were (looking at the picture close up, you connect to the right-most diode pins, which connect to the inputs of the regulators, not the left-most pins, which connect to each other!!)
yes. The picture is very small. It seems the “free” image host re-sized it for me…
No need to host elsewhere … You can attach images to your post, or if it is something which may need to be kept for documentation, I will be happy to upload it to the wiki for you :slight_smile:
Okay, well considering I can’t really seem to test the voltages I’ll just pop some new amps in and see if they fizz.
