Few quad sid questions
If i have completed my quad sid how can i or must i :
A: update the mios or sid software? Do they go all at once? Or must i flash them seperatly (stuff unstuff).
B: change midi chanel for each sid (or do i have only 1 midichannel?) trough control surface.
Thx in advance
Hi Twin-X,
there is a new description which describes the required steps:
http://www.ucapps.de/midibox_sid_csB.html
(search for “Preparation of PIC18F cores”)
Once this has been done, you can change the MIDIchannel of each SID (seperately of course…) in the CFG menu
Step by step:
I read this over and over and over :smiley:
Do i stuff all cores at once. Power the unit.
Use the link cable of JDM to prepare the master and finish it all. After testing sid 1 i connect this cable to slaves 1 by 1? And repeat the procedure (according to the steps in the step by step guide)
Sorry if i sound confusing
p.s. the cores j10 only have 4 wires connected right?
are these questions or conclusions? :wink: Of course, if you haven’t programmed the bootloader into the slaves, it’s time to do it now. And please don’t forget to set the ID of the slaves to 1, 2 and 3!
J10 has 4 connections if the ground is already connected from the power supply unit to the SID module — compare the wiring with http://www.ucapps.de/mbhp/mbhp_4xsid_c64_psu_optimized.pdf
Thanks for the info.
Regards,
Jeffry
