Fast Scan Matrix 4
I’m having some problems in trying to use a rotary switch to change the the Midi Channel.
There are some unused Shift Registers locations that I refer to as BANK 0 and BANK 1. See attached Table
I have allocated pins 80, 81, 82, 83 to the pins of the the HEX switch and had hoped to generate values (1 - 9) and (a - f).
I have used pins 84 and 85 to connect to the soft pedal and the sustain pedal switches.
The code for both is shown
//non-key switches
	if((column >=0 && column <=7 ) && (row >= 10 && row <= 11)){
	pin = 8* row + column;
	if(pin == 84 && pin_value == 0) { // send soft pedal CC
  MIOS32_MIDI_SendCC (KEYBOARD_MIDI_PORT,KEYBOARD_MIDI_CHN, 67, 127 ) ;}
   if(pin == 84 && pin_value == 1) {
  MIOS32_MIDI_SendCC (KEYBOARD_MIDI_PORT, KEYBOARD_MIDI_CHN, 67, 0 );}
   if(pin == 85 && pin_value == 0) {// send sustain pedal CC
   MIOS32_MIDI_SendCC (KEYBOARD_MIDI_PORT,KEYBOARD_MIDI_CHN , 64, 127 );}
   if(pin == 85 && pin_value == 1) {
   MIOS32_MIDI_SendCC (KEYBOARD_MIDI_PORT,KEYBOARD_MIDI_CHN , 64, 0 );}
   //channel select
   //uses pins (80 - 83) with 16 bit rotary Switch to give (0 - 9, a - f)
	"Red Code"
	if (pin == 80 && pin_value == 0) { w = 1;} //lsd bit
	if (pin == 80 && pin_value == 1) { w = 0;} //lsd bit
	if (pin == 81 && pin_value == 0) { x = 2;}
	if (pin == 81 && pin_value == 1) { x = 0;}
	if (pin == 82 && pin_value == 0) { y = 4;}
	if (pin == 82 && pin_value == 1) { y = 0;}
	if (pin == 83 && pin_value == 0) { z = 8;} //msd bit
	if (pin == 83 && pin_value == 1) { z = 0;}	//msd bit
	//Chn = (w + x + y + z);
        "End of Red Code"
 	MIOS32_MIDI_SendCC (KEYBOARD_MIDI_PORT,(w + x + y + z) , 30 , 0);// 30 (0x1e)undefined, 0 arbitrary
	//right hand keys
The system does change the midi channel but the code in red does not work. I get only get a few channel values.
I suspect that the switch is no compatible and that the scan matrix is not suitable.
Is this suspicion correct?
I also think that I may be able to use a rotary switch where only only one pin of (say) 8 pins is connected to 0V at any time. (break-before-make type.) I think that any bounce would be tolerable. (giving multiple midi channel requests for the same channel)
Does this make sense.
Should I use the MIOS32 Encoder Functions with rotary edge hex switches?
Thanks
Robin
After I sent the above I read about the use of encoders with J5. These inputs configured as digital inputs will hopefully allow me to use three rotary hex switches without any more SR’s. Three such switches will allow me to control the Midi Channel No and the other two will be used to adjust the keyboard_delay_fastest and
keyboard_delay_slowest variables.
Is this the way to go?
[Connectin Diagram MIOS 32 Fast Scan with extra switches.doc](< base_url >/applications/core/interface/file/attachment.php?id=7878)
Dear All
I have moved on a little since the previous message. One thought is to use J5 A,B and C pins. It seems possible to use the 12 pins, 8 pins could be configured as digital inputs and up to 4 pins as digital output.
The combination could be used with diodes to provide a 4 X 8 diode matrix. This would provide more than enough scanned pins for my current needs needs.
I will use Tutorial 5 and 6 as a starting point.
I’m not too sure about the integration with Thorsten’s Fast Scan Matrix example and the RTOS aspects.
More later.
Robin
I have progressed a little using Tutorial 006 RTOS and have programmed the behaviour of the hex and other switches to J5 inputs. I used a lead connected to OV as the "“row enable” for my 2 X 8 matrix using J5.
I then tried to use pin 8 and 9 of J5 as outputs. I have initialised the pins as follows
MIOS32_BOARD_LED_Init(0xffffffff);
  // initialize pins 0 - 7 of J5A, J5B and J5C as inputs with internal Pull-Up
  int pin;
  for(pin=0; pin<8; ++pin)// only 8 Inputs - leaves 4 Outputs
    MIOS32_BOARD_J5_PinInit(pin, MIOS32_BOARD_PIN_MODE_INPUT_PU);
	for (pin=8; pin <12; ++pin)
	MIOS32_BOARD_J5_PinInit(pin, MIOS32_BOARD_PIN_MODE_OUTPUT_PP);
and have programmed the output pin to be 0V as follows.
//s32 MIOS32_BOARD_J5_PinSet	(	u8 pin, u8 value)
//set J5 pin 8 to 0
	MIOS32_BOARD_J5_PinSet	(8, 0);
I have checked all 4 output pins they are all 3v.
I have looked at the code on MIOS32_BOARD .c but can not see that I have overlooked anything.
It seems to me that I should be able to use J5 pins to make a small diode matrix. I have assumed that it is possible to have 8 inputs and 4 outputs. Perhaps I am mistaken or is it a coding problem?
Please help.
Robin
I now realise that I can change the pin polarity of any J5 pin programmed as an input and that I don’t need to have outputs to do this! Sorry!
I sent this message before. After sending it, I thought that I could program the input to the input using “J5 set” It may well have this effect, internally but it will not drive my diode matrix.I need a Digital output.
Have a look at the initialisation code.
Can you mix the 12 pins between inputs and outputs? Also is the output mode pp the correct one? For that matter is the input mode correct?
  int pin;
//set J5 pin 8 to 0
Perhaps I have a coding problem?
I have tried many variations but I cannot manage to change the state of the the output pins 8 and 9. I’m very frustrated!
I will appreciate any help.
Robin
Ooofff.. sometimes you’re doing challenging projects :wink:
Pin #8 and #9 should work as outputs with your initialization routine.
I just have doublechecked this on my board.
You could measure the voltage directly on the pins of the STM32 chip (see schematic), just to ensure that they are correctly soldered.
To the original problem (connect the switch to the scan matrix, first topic of this post):
did you already add some debug messages just to check if and when the routine is executed, and what are the results in w/x/y/z on any switch movement?
Such messages are really helpful to get a better understanding of the internal processing
Thanks Thorsten
It was useful to have the confirmation that J5 could have a mix of inputs and outputs.
I looked at the connections again and found that I had transposed 2 of the 3 cables to the small J5 diode matrix board. Silly me! At this point in time I have proved that MIOS32_BOARD_J5_PinSet works for both pins 8 and 9.
Now I need to program these operations sequentially.
Once this task is completed I need to integrate the modified 006 RTOS tutorial into the Fast Matrix Scan Example.
You will recall that I initially tried to use the Fast Scan Matrix Example with the 2 Pedals and 3 hex switches. The Pedals are made by the keyboard manufacturer, Fatar. They seem to be using the same type of switch for the pedal as they use for the keys ie a membrane switch; this type seems to have little or no bounce. It worked fine with the Pedals but gave unpredictable results with both types of hex switch. The Midi Channel switch will be fitted on the small console is a Cherry type Series E (0-9, A-F). The other type will be used to control the Delay variables to alter the velocity response. These will not be on show, They are a small pcb type and are are mounted on the J5 Diode Matrix board.
The problem I think is that the Fast Matrix scan program deals with detecting 1-0 transitions. The hex switches rely on 4 wipers making contact with pcb tracks arranged to produce a parallel 4 output Hex code. There is an inherent lack of precision whereby the final contact should produce a 1 but is preceded by a 1-0 transition. The 1 state will not be detected. Hence an error is made.
For these reasons I decided to opt for the J5 matrix approach.
Many thanks again.
Robin
You could do the same with the matrix approach by implementing some kind of “low pass filter”.
Just define a global counter, and a second variable which stores the state of the hex switch.
u8 hex_switch_counter = 0;
u8 hex_switch_state = 0;
[/code]
In BUTTON_NotifyToggle change the state according to the pin change, and set the counter to a certain value - let's say 50
Don't react immediately on this change (e.g. don't send a MIDI event)
Instead, add following routine to TASK_MatrixScan()
[code]
 if( hex\_switch\_counter ) {
 --hex\_switch\_counter;
 if( !hex\_switch\_counter) { // counter reached 0
 // do something with hex\_switch\_state...
In other words: whenever the hex switch changes it’s state, wait for 50 mS before doing something with the new state.
Thanks very much Thorsten
I will try this approach. It is much better to use the existing Example Fast Scan Matrix rather than introducing myJ5 method.
Regards Robin
