Hmmm, actually, the relay circuit clicks on - then of after about ½ a second, when I toggle S#1 to “*” in patch root -> EXT. Nothing happens when I toggle back to “0”.
I have the core on a pcb from smash TV, so there are 2 jumper rows (J5a and J5b). There’s 5v at the beginning of each row. Connecting the circuit here works as intended. I’ve tried looking at the RA pins with a scope while switching the states. There’s a short change, then back to low.
Erhm…do the unused ports need pull down resistors?
With the settings specified in the beginning of the thread, the RA0, RA1 (etc.) pins should stay in the toggled state, and not just flip back to 0 right?
Once again, thanks for your kind help Yesterday I tried it out again, but forgot to dial to the patch I’ve used for aout testing. So with the default patch, the switching worked as intended. I haven’t tried the init yet, but it seems there’s something in the patch I used earlier, that influenced the switching. I 'll get thing hooked up a bit more consistently (inside the case, without crocodile clips) :), and see how it behaves from there. Cheers
I also noticed that with some patches it can happen that the AOUT or triggers aren´t working as expected. Sume other functions as well, seems rather strange and hard to repeat. I have another thread about this, but i just saw yours.
Propably it has to do with new assignments in the setup file in conjunction with older patches. Problem is i always noticed this late, so i cannot say what changes exactly made this happen.
In my case Trigger 1 and 8 are not working on my slave core, on my master core i had the same problem with triggers falling back to 0.
Maybe someone else besides TK can check on this or confirm it is working for them… Someone with a MB_SID using all triggers, or with an “exposed” core module so they don´t need to take stuff appart. Then at least we know it´s not a bug (what i actually doubt) but some mistake at our side (although i carefully inspected solder joints a thousand times).
