Example for MIOS
Hello,
i have download this software:
ActivePerl-5.8.8.819-MSWin32-x86-267479.msi
gputils-0.13.4-1.exe
sdcc-2.6.0-setup.exe
and:
MIOSStudio_beta7_4.jar
sdcc_skeleton_v1_9a.zip
When i make the main.c (skeleton example file) the SDCC create a project.hex  :slight_smile:
I load this file in MIOS Studio (MIOS Hex File Upload 1 -> Hex File)
When i press the start button, in the Midi monitor Out write:  ???
timestamp [unknown] | Sysex message: F0 00 00 7E 40 00 02 0C 00 00
20 43 7B 63 1F 04 37 5E 19 78 24 7D 71 4F 42 45 6F 0C 7C 14 3E 78
67 61 29 77 46 3E 0E 2F 3C 33 70 7A 3B 63 1F 06 57 5E 19 78 37 3D
71 4F 40 07 6F 0D 3C 19 5E 78 67 61 47 77 46 3E 0A 7F 3C 33 70 5D
3B 63 1F 04 03 5E 19 78 20 3D 71 4F 42 05 6F 0C 7C 10 3E 78 67 61
54 77 46 3E 0D 1F 3C 33 70 42 3B 63 1F 04 17 5E 19 78 21 5D 71 4F
40 24 00 00 00 02 20 00 00 00 12 00 00 00 01 10 00 00 00 09 00 00
00 00 48 00 00 00 04 40 00 00 00 24 00 00 00 1F 7F 7F 7F 7F 7F 7F
7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F
7F 7F 7F 7F 7F 7F 7F 78 20 F7
Is correct this condition ?  ???
You can help me for send the “C note” ON and OFF (for example) ?  8)
Thanks
xoooox
// NOTE ON
  MIOS_MIDI_TxBufferPut(0x90); // Note Event at channel #1
  MIOS_MIDI_TxBufferPut(48);  // Note number (0..127)
  MIOS_MIDI_TxBufferPut(0x7f); // Velocity = (0..127)
// NOTE OFF
  MIOS_MIDI_TxBufferPut(0x00); // Velocity = (0..127)
if i write “MIOS_MIDI_TxBufferPut… (NOTE ON)” in the function “Init(void)” and press Start Button (MIOS Hex File Upload)
In the “Midi monitor out” is alike at previous post (Posted on: Today at 09:18)  :cry:
Why ???  :-[
Where i error ?  :-\
Thanks
xoooox
Hello xoooox,
it is quite normal, that you see your program when you upload it.
I mean, I’m no binary talking computer, but this looks like a small MIOS-application.
Now wait until MIOS restarts the box and your Init() function should be processed.
If not, then check if you’re uploading the right file.
Maybe connect also an LCD. With MIOS_Print_…() you can see what’s going on and don’t have to peek in the Midi Monitor.
If you’re looking for more examples, see this page:
http://www.ucapps.de/mios_c.html
(scroll down to the bottom of this page and you’ll find a bunch of C-Examples!)
regards,
AC
