EVENT_RGBLED help
I’ve been playing around with illuminated encoders and the results are nice (promise a video soon!). For the most part, the NG events work well to change the hsv colour, or brightness using dimmed=1.
I’m wondering about bipolar controls though – e.g. where you might represent CC* values of 0-63 as negative and 64-127 as positive. I find it’s okay to use range=MAP* as a hack to assign red to “negative” and green to “positive” values, and also to use a dimming function e.g.:
#hue map (red 0-49, yellow 50, green 51-100) MAP1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 \ 0 0 0 0 0 0 0 0 0 0 0 0 60 120 120 120 120 120 120 120 120 120 120 120 120 120 \ 120 120 120 120 120 120 120 120 120 120 120 120 120 120 120 120 120 120 120 120 \ 120 120 120 120 120 120 120 120 120 120 120 120 120 120 120 120 120 #value (i.e. brightness) map (value 100-0-100) MAP2 100 98 96 94 92 90 88 86 84 82 80 78 76 74 72 70 68 66 64 62 60 58 56 54 52 \ 50 48 46 44 42 40 38 36 34 32 30 28 26 24 22 20 18 16 14 12 10 8 6 4 2 0 2 4 6 8 \ 10 12 14 16 18 20 22 24 26 28 30 32 34 36 38 40 42 44 46 48 50 52 54 56 58 60 62 \ 64 66 68 70 72 74 76 78 80 82 84 86 88 90 92 94 96 98 100
but it would be nice to combine the two. Thus you might have the LED off in the centre position, and fade up to full red or green depending on the direction. I can also think of other usecases e.g. a unipolar level control increasing in brightness from zero to green to yellow to red.
All of my efforts so far have failed, including trying to put conditional statements in the .NGC, running simple SET_HSV commands in .NGR, various arrangements of EVENTs etc. I assume (as well as being naive) that the RGBLED events are conflicting, and only the most recent one takes priority.
So, any ideas for controlling both the “h” and “v” parts of EVENT_RGBLED separately?
Hi
Not sure to completely get it,
but did you try your encoder forwarding to a sender, with as many requested sender id (same hw_id sender) forwarding to led.
Best
Zam
sending 16 bits as 8bits H +8bits V concatenated and parse? idk if possible for real,just a naive guess.
Maybe for real coding, but this is MIOS so everything’s a MIDI stream with limited parameters.
2 hours ago, Zam said:
Hi
Best
Zam
I did play around with senders and multiple ids/hw_ids, but there’s still the problem of one EVENT_RGBLED overwriting the other.
Eventually I could get it to work in a script, but it’s pretty crude
NGR:
if ^section == 0
  exec_meta RunSection:1
endif
#testing purposes, called at the same time as .NGC
if ^section == 1
  log "Section 1 called"
  if ENC:3 < 50
    set_hsv RGBLED:3 0:100:50
  elseif ENC:3 == 50
    set_hsv RGBLED:3 60:100:60
  else
    set_hsv RGBLED:3 120:100:50
  endif
  delay_ms 100
  exit
endif
#loops until "runstop" is entered into MIOS terminal :s
NGC:
ENC n=3 sr=1 pins=5:4 type=detented1 enc\_speed\_mode=Fast:5 EVENT\_ENC id=3 fwd\_id=RGBLED:3 fwd\_to\_lcd=1 type=CC chn= 1 CC= 18 range=0:100 lcd\_pos=11:1:1 label="ENC #%3i %5d%B" EVENT\_RGBLED id=3 hsv=0:100:50 dimmed=1 range=MAP3
I hope there’s a nicer way to implement it.
