Ethernet Help
So I am trying to connect my mbseq with lpc17 core to my network and I am having some issues. I get the following error in mios studio. The error continuously repeats.
[9653.302] [EMAC_ReadPacket] ERROR during receive:
[9653.302] [network_device_read] - Multicast Frame
[9653.304] [network_device_read] - Broadcast Frame
[9653.304] [network_device_read] - CRC Error in Frame
[9653.304] [network_device_read] - Symbol Error from PHY
[9653.306] [network_device_read] - Range error(exceeded max size)
[9653.306] [network_device_read] - last Fragment in Frame
Any ideas?
Thanks,
Luke
Hi midiboxer’s,
i have the same problem on 2 lpcCores (mbseqv4l / midiboxNG).
I tried several configurations when directly connected to a laptop or connected to a fritzbox router ( w/o DHCP or with static IP config )
thanks in advance
Henrik
This is strange! It seems that invalid frames are sent in the network.
I hope that at least the actual OSC packets are sent/received correctly.
Could you please try this version? (I disabled the error message):
-> http://www.ucapps.de/mios32/midibox_seq_v4_079_pre5.zip
Thanks a lot  for your fast help: :smile:   I will try it out tomorrow evening ^^ Have to sleep now :(  gn8
Ethernet PHY error messages are now disabled by default in the new releases V4.079 and V4L.079
Thanks TK this fixed my issue, seems to be connecting fine now!
Great!  :smile:
