error compiling c app
hi,
could someone explain me why when compiling my app i get this error in many file:
“processor type not defined”
It’s not what you’d expect either… The processor does seem to be defined in the source… I’m looking at it now…
i’ve re-do all the work from scratch, and the only error i get now are:
.objs\aout.asm:598:Error [103] syntax error
.objs\aout.asm:600:Error [113] Symbol not previously defined (reg).
.objs\aout.asm:600:Error [113] Symbol not previously defined (bit).
.objs\aout.asm:605:Error [145] Unmatched ENDM.
.objs\aout.asm:606:Error [174] Unknown opcode “CV_AOUT_LC_WRITE_BIT”
.objs\aout.asm:607:Error [174] Unknown opcode “CV_AOUT_LC_WRITE_BIT”
.objs\aout.asm:608:Error [174] Unknown opcode “CV_AOUT_LC_WRITE_BIT”
.objs\aout.asm:609:Error [174] Unknown opcode “CV_AOUT_LC_WRITE_BIT”
.objs\aout.asm:610:Error [174] Unknown opcode “CV_AOUT_LC_WRITE_BIT”
.objs\aout.asm:611:Error [174] Unknown opcode “CV_AOUT_LC_WRITE_BIT”
.objs\aout.asm:612:Error [174] Unknown opcode “CV_AOUT_LC_WRITE_BIT”
.objs\aout.asm:613:Error [174] Unknown opcode “CV_AOUT_LC_WRITE_BIT”
.objs\aout.asm:614:Error [174] Unknown opcode “CV_AOUT_LC_WRITE_BIT”
.objs\aout.asm:615:Error [174] Unknown opcode “CV_AOUT_LC_WRITE_BIT”
.objs\aout.asm:616:Error [174] Unknown opcode “CV_AOUT_LC_WRITE_BIT”
.objs\aout.asm:617:Error [174] Unknown opcode “CV_AOUT_LC_WRITE_BIT”
.objs\aout.asm:618:Error [174] Unknown opcode “CV_AOUT_LC_WRITE_BIT”
.objs\aout.asm:619:Error [174] Unknown opcode “CV_AOUT_LC_WRITE_BIT”
.objs\aout.asm:620:Error [174] Unknown opcode “CV_AOUT_LC_WRITE_BIT”
.objs\aout.asm:621:Error [174] Unknown opcode “CV_AOUT_LC_WRITE_BIT”
any suggestion?
Warning - while you were typing a new reply has been posted. You may wish to review your post.
Hah, I just figured it out too :smiley: ROFL…That’s 3 hours wasted! :wink:
Hey mail me the new one and I’ll scope it out.
email coming your way… Let me know if it works, I’ll document it more neatly for the wiki…
thanks, i will spend the  night on this  :stuck_out_tongue:
i’ve tried to integrate the code you give me,
now i just get this two errors:
Compiling: aout.c
aout.c:267:19: warning: no newline at end of file
aout.c:185: syntax error: token -> ‘void’ ; column 10
what is wrong?
this one is pretty easy: just make a new line at the end of the file, so that the file does not end with a char but a blank line!
could you post a snippet (maybe lines 180 to 190) of aout.c?
cheers,
AC
thanks  i’ve solved this first errors.
now i get this one:
aout.c:213: syntax error: token -> ‘’ ; column 0
Process terminated with status 1 (0 minutes, 1 seconds)
1 errors, 0 warnings
here is a quote of the 4 last line of my file:
210:      bcf    CV_AOUT_LC_LAT_RCLK, CV_AOUT_LC_PIN_RCLK ; release latch
211:endasm;
213;  }
214:
Hi moxi,
I think you have to add two underscores before calling
[tt]__asm
asmcontent…bla…
__endasm;[/tt]
best,
Michael
btw: is it normal that there’s line 212 missing or have I watched too much doctor who investigating dissapearing things ;D
oups! it’s me that forgot it!
now, with the underscores before asm and endasm:
syntax error: token -> ‘__endasm’ ; column 8
can you post a bit more, so that I can see the whole logical snippet?
is everything allright with “__asm” in the beginning of the token? (eg. no “;” after “__asm”)?
here is my file in this last state, i’ve added all the code needed (i think):
include “cmios.h”
include “pic18f452.h”
include “main.h”
include “aout.h”
// Global variables
// AOUT values
unsigned int aout_value[8];
// stores the last AOUT values (to determine, if the shift registers have to be updated)
unsigned int last_aout_value[8];
// the gate pins
aout_gates_t aout_gates;
// last state of the aout gate flags to determine changes
aout_gates_t last_aout_gates;
// This function initializes the AOUT module
void CV_AOUT_LC_Init(void) {
__asm
;; enable pin drivers
bcf CV_AOUT_LC_TRIS_RCLK, CV_AOUT_LC_PIN_RCLK
bcf CV_AOUT_LC_TRIS_DOUT, CV_AOUT_LC_PIN_DOUT
bcf CV_AOUT_LC_TRIS_SCLK, CV_AOUT_LC_PIN_SCLK
;; set voltages to 0V
lfsr FSR0, AOUT0_L
movlw 8
movwf MIOS_PARAMETER3 ; used as loop counter here
CV_AOUT_LC_InitVoutLoop
clrf POSTINC0
movlw 0x80
movwf POSTINC0
decfsz MIOS_PARAMETER3, F
rgoto CV_AOUT_LC_InitVoutLoop
;; update the AOUT pins
rcall CV_AOUT_LC_Update
return
__endasm;
void CV_AOUT_LC_Load2SR(void) {
    __asm
        bcf    CV_AOUT_LC_LAT_SCLK, CV_AOUT_LC_PIN_SCLK ; clear clock
;; superfast transfer with unrolled loop (takes some memory, but guarantees the
;; lowest system load :slight_smile:
CV_AOUT_LC_WRITE_BIT MACRO reg, bit
bcf CV_AOUT_LC_LAT_DOUT, CV_AOUT_LC_PIN_DOUT ; set out pin depending on register content (reg.bit)
btfsc reg, bit
bsf CV_AOUT_LC_LAT_DOUT, CV_AOUT_LC_PIN_DOUT
nop
        bsf    CV_AOUT_LC_LAT_SCLK, CV_AOUT_LC_PIN_SCLK ; rising clock edge
        bcf    CV_AOUT_LC_LAT_SCLK, CV_AOUT_LC_PIN_SCLK ; falling clock edge
ENDM
CV_AOUT_LC_WRITE_BIT TMP1, 7
CV_AOUT_LC_WRITE_BIT TMP1, 6
CV_AOUT_LC_WRITE_BIT TMP1, 5
CV_AOUT_LC_WRITE_BIT TMP1, 4
CV_AOUT_LC_WRITE_BIT TMP1, 3
CV_AOUT_LC_WRITE_BIT TMP1, 2
CV_AOUT_LC_WRITE_BIT TMP1, 1
CV_AOUT_LC_WRITE_BIT TMP1, 0
CV_AOUT_LC_WRITE_BIT TMP2, 7
CV_AOUT_LC_WRITE_BIT TMP2, 6
CV_AOUT_LC_WRITE_BIT TMP2, 5
CV_AOUT_LC_WRITE_BIT TMP2, 4
CV_AOUT_LC_WRITE_BIT TMP2, 3
CV_AOUT_LC_WRITE_BIT TMP2, 2
CV_AOUT_LC_WRITE_BIT TMP2, 1
CV_AOUT_LC_WRITE_BIT TMP2, 0
;; this must be done once all SRs in the chain have been uploaded!
#if 0
        bsf    CV_AOUT_LC_LAT_RCLK, CV_AOUT_LC_PIN_RCLK ; latch SID values
bcf CV_AOUT_LC_LAT_DOUT, CV_AOUT_LC_PIN_DOUT ; clear out pin (standby)
#endif
__endasm;
void CV_AOUT_LC_LoadAOUTx_8_8(void)
__asm
;; 8bit/8bit
swapf PREINC1, W ; AOUT0_H[3:0] -> TMP2[7:4]
andlw 0xf0
movwf TMP2
movf POSTDEC1, W ; AOUT0_L
swapf INDF1, W ; AOUT0_L[7:4] -> TMP2[3:0]
andlw 0x0f
iorwf TMP2, F
movf POSTINC1, W ; AOUT0_H
movf POSTINC1, W ; AOUT1_L
swapf PREINC1, W ; AOUT1_H[3:0] -> TMP1[7:4]
andlw 0xf0
movwf TMP1
movf POSTDEC1, W ; AOUT1_L
swapf INDF1, W ; AOUT1_L[7:4] -> TMP1[3:0]
andlw 0x0f
iorwf TMP1, F
bsf POSTINC1, 7 ; AOUT1_H
movf POSTDEC1, W ; AOUT0_H
bsf INDF1, 7 ; AOUT0_H
rgoto _CV_AOUT_LC_Load2SR
__endasm;
//  FUNCTION: CV_AOUT_LC_Update
//  DESCRIPTION: refreshes the AOUT pins if AOUT values have been changed
//  OUT:  -
//  USES: TMP[12345] and MIOS_PARAMETER[12]
void CV_AOUT_LC_Update(void) {
__asm
;; check if any output has to be updated
IFCLR AOUT0_H, 7, rgoto CV_AOUT_LC_Update_SRs
IFCLR AOUT1_H, 7, rgoto CV_AOUT_LC_Update_SRs
IFCLR AOUT2_H, 7, rgoto CV_AOUT_LC_Update_SRs
IFCLR AOUT3_H, 7, rgoto CV_AOUT_LC_Update_SRs
IFCLR AOUT4_H, 7, rgoto CV_AOUT_LC_Update_SRs
IFCLR AOUT5_H, 7, rgoto CV_AOUT_LC_Update_SRs
IFCLR AOUT6_H, 7, rgoto CV_AOUT_LC_Update_SRs
IFCLR AOUT7_H, 7, rgoto CV_AOUT_LC_Update_SRs
rgoto _CV_AOUT_LC_Update_NoSRs
__endasm;
void CV_AOUT_LC_Update_SRs(void) {
__asm
lfsr FSR1, AOUT6_L ; loads AOUT6_[LH] and AOUT7_[LH]
rcall CV_AOUT_LC_LoadAOUTx_8_8
lfsr FSR1, AOUT4_L ; loads AOUT4_[LH] and AOUT5_[LH]
lfsr FSR1, AOUT2_L ; loads AOUT2_[LH] and AOUT3_[LH]
lfsr FSR1, AOUT0_L ; loads AOUT0_[LH] and AOUT1_[LH]
rcall _CV_AOUT_LC_LoadAOUTx_8_8
__endasm;
i’ve added properly the __asm and endasm; for each parts…now the reports tell me that a lot of symbol are not defined (MIOS_PARAMETER3,POSTINC0,INDF1…)it’s like the asm code was not integrated correctly… :frowning:
as the snippet has just 193 lines, I expect the error has been before…
let’s see what looks suspicious:
  • line 54: you should move the [tt]return[/tt] after the [tt]__endasm; [/tt]==>
[tt]__endasm;
return;
}[/tt]
  • line 93: [tt]#if 0[/tt]
if 0 will never be true and therefore will never be processed? is that okay?
in cases like these, there might be an error in the header file?
besides the “return;” I can see no syntax error.
[tt]MIOS_PARAMETER3[/tt] is declared in cmios.h wich is included correctly. let’s see if that [tt]return; [/tt]solves it…
there is only header text before, this is the full file..
your hint don’t solve the problems, here is a quote of the errors reports:
.objs\aout.asm:216:Error [108] Illegal Character (,)
.objs\aout.asm:216:Error [128] Missing argument(s).
.objs\aout.asm:217:Error [113] Symbol not previously defined (CV_AOUT_LC_LoadAOUTx_8_8).
.objs\aout.asm:218:Error [108] Illegal Character (,)
.objs\aout.asm:218:Error [128] Missing argument(s).
.objs\aout.asm:219:Error [113] Symbol not previously defined (CV_AOUT_LC_LoadAOUTx_8_8).
.objs\aout.asm:220:Error [108] Illegal Character (,)
.objs\aout.asm:220:Error [128] Missing argument(s).
.objs\aout.asm:221:Error [113] Symbol not previously defined (CV_AOUT_LC_LoadAOUTx_8_8).
.objs\aout.asm:222:Error [108] Illegal Character (,)
.objs\aout.asm:222:Error [128] Missing argument(s).
.objs\aout.asm:224:Error [128] Missing argument(s).
.objs\aout.asm:225:Error [128] Missing argument(s).
.objs\aout.asm:226:Error [128] Missing argument(s).
.objs\aout.asm:237:Error [103] syntax error
.objs\aout.asm:238:Error [103] syntax error
.objs\aout.asm:239:Error [103] syntax error
.objs\aout.asm:240:Error [103] syntax error
.objs\aout.asm:241:Error [103] syntax error
.objs\aout.asm:242:Error [103] syntax error
.objs\aout.asm:243:Error [103] syntax error
.objs\aout.asm:244:Error [103] syntax error
.objs\aout.asm:245:Error [174] Unknown opcode “rgoto”
.objs\aout.asm:256:Warning [203] Found opcode in column 1.
.objs\aout.asm:257:Error [103] syntax error
.objs\aout.asm:260:Error [113] Symbol not previously defined (TMP2).
.objs\aout.asm:262:Warning [203] Found opcode in column 1.
.objs\aout.asm:262:Error [113] Symbol not previously defined (INDF1).
.objs\aout.asm:263:Error [103] syntax error
.objs\aout.asm:266:Error [113] Symbol not previously defined (TMP2).
.objs\aout.asm:267:Error [113] Symbol not previously defined (POSTINC1).
.objs\aout.asm:268:Error [113] Symbol not previously defined (POSTINC1).
.objs\aout.asm:269:Warning [203] Found opcode in column 1.
.objs\aout.asm:270:Error [103] syntax error
.objs\aout.asm:273:Error [113] Symbol not previously defined (TMP1).
pic16_allocRegByName:963 symbol name _aout_value regop= 00000000
.objs\aout.asm:275:Warning [203] Found opcode in column 1.
pic16_allocRegByName:963 symbol name _last_aout_value regop= 00000000
.objs\aout.asm:275:Error [113] Symbol not previously defined (INDF1).
pic16_allocRegByName:963 symbol name _aout_gates regop= 00000000
pic16_allocRegByName:963 symbol name _last_aout_gates regop= 00000000
.objs\aout.asm:276:Error [103] syntax error
.objs\aout.asm:279:Error [113] Symbol not previously defined (TMP1).
.objs\aout.asm:280:Error [113] Symbol not previously defined (POSTINC1).
.objs\aout.asm:283:Error [113] Symbol not previously defined (INDF1).
.objs\aout.asm:285:Error [174] Unknown opcode “rgoto”
.objs\aout.asm:295:Error [128] Missing argument(s).
.objs\aout.asm:298:Error [103] syntax error
.objs\aout.asm:299:Error [128] Missing argument(s).
.objs\aout.asm:300:Error [113] Symbol not previously defined (reg).
.objs\aout.asm:300:Error [113] Symbol not previously defined (bit).
.objs\aout.asm:301:Error [128] Missing argument(s).
.objs\aout.asm:303:Error [128] Missing argument(s).
.objs\aout.asm:304:Error [128] Missing argument(s).
.objs\aout.asm:305:Error [145] Unmatched ENDM.
.objs\aout.asm:306:Error [174] Unknown opcode “CV_AOUT_LC_WRITE_BIT”
.objs\aout.asm:307:Error [174] Unknown opcode “CV_AOUT_LC_WRITE_BIT”
.objs\aout.asm:308:Error [174] Unknown opcode “CV_AOUT_LC_WRITE_BIT”
.objs\aout.asm:309:Error [174] Unknown opcode “CV_AOUT_LC_WRITE_BIT”
.objs\aout.asm:310:Error [174] Unknown opcode “CV_AOUT_LC_WRITE_BIT”
.objs\aout.asm:311:Error [174] Unknown opcode “CV_AOUT_LC_WRITE_BIT”
.objs\aout.asm:312:Error [174] Unknown opcode “CV_AOUT_LC_WRITE_BIT”
.objs\aout.asm:313:Error [174] Unknown opcode “CV_AOUT_LC_WRITE_BIT”
.objs\aout.asm:314:Error [174] Unknown opcode “CV_AOUT_LC_WRITE_BIT”
.objs\aout.asm:315:Error [174] Unknown opcode “CV_AOUT_LC_WRITE_BIT”
.objs\aout.asm:316:Error [174] Unknown opcode “CV_AOUT_LC_WRITE_BIT”
.objs\aout.asm:317:Error [174] Unknown opcode “CV_AOUT_LC_WRITE_BIT”
.objs\aout.asm:318:Error [174] Unknown opcode “CV_AOUT_LC_WRITE_BIT”
.objs\aout.asm:319:Error [174] Unknown opcode “CV_AOUT_LC_WRITE_BIT”
.objs\aout.asm:320:Error [174] Unknown opcode “CV_AOUT_LC_WRITE_BIT”
.objs\aout.asm:321:Error [174] Unknown opcode “CV_AOUT_LC_WRITE_BIT”
.objs\aout.asm:323:Error [128] Missing argument(s).
.objs\aout.asm:324:Error [128] Missing argument(s).
.objs\aout.asm:325:Error [128] Missing argument(s).
.objs\aout.asm:336:Error [128] Missing argument(s).
.objs\aout.asm:337:Error [128] Missing argument(s).
.objs\aout.asm:338:Error [128] Missing argument(s).
.objs\aout.asm:340:Error [108] Illegal Character (,)
.objs\aout.asm:340:Error [128] Missing argument(s).
.objs\aout.asm:342:Error [113] Symbol not previously defined (MIOS_PARAMETER3).
.objs\aout.asm:343:Error [174] Unknown opcode “CV_AOUT_LC_InitVoutLoop”
.objs\aout.asm:344:Error [113] Symbol not previously defined (POSTINC0).
.objs\aout.asm:346:Error [113] Symbol not previously defined (POSTINC0).
.objs\aout.asm:347:Error [113] Symbol not previously defined (MIOS_PARAMETER3).
.objs\aout.asm:348:Error [174] Unknown opcode “rgoto”
.objs\aout.asm:350:Error [113] Symbol not previously defined (CV_AOUT_LC_Update).
where have I to define this symbols?
Moxi,
you just have to care about the very first errors. Most time the rest of the errors are a result of the first one.
An illegal character is reported right before CV_AOUT_LC_LoadAOUTx_8_8, if I count these line-numbers (113) up to 108, this brings us straight to your “#if 0” thing.
please remove this completely from the code and compile again:
#if 0
#endif
When I think about it, it seems very likely that C-preprocessor directors are not supported in ASM codesnippets!
I bet this is it!
it’s the same report with removing what you say.. :frowning:
can you send me both the header and the source file and I see if I can compile it…
yes:
http://soundandbreakfast.ifrance.com/divers/aout.c
http://soundandbreakfast.ifrance.com/divers/aout.h
