Encoder specifications
I’m hoping this is going to be a sticky topic :wink:
I’ll edit this post or delete it, if it’s not needed anymore - all this information is gathered from the forum, and shamelessly copied here - You’re welcome to present it in a better form
Bourns PEC11-series detented encoders
(From SmashTV)
Encoder mode: “DETENTED2”
Pinout: (http://www.avishowtech.com/mbhp/images/encspecs17.gif)
Note: the rightmost picture is “top down” (as seen from the top of the encoder looking down to the shaft)
pin “A” goes to D1
pin “C” goes to Vs
pin “B” goes to D0
(This means that, encoder C pin is “common”. Encoder B pin goes to lower numbered DIN pin (of two pins assigned to that encoder) and encoder A pin to higher numbered DIN pin.)
the detent can be removed
Thanks go to:
mandingo: http://69.56.171.55/~midibox/forum/index.php?topic=3843.msg25094#msg25094
jdutcher: http://69.56.171.55/~midibox/forum/index.php?topic=3911.msg25766#msg25766
xcoulonx: http://69.56.171.55/~midibox/forum/index.php?topic=3299.msg23699#msg23699
Now - does anyone want to reveal the specs of the encoders from VOTI? What about different ALPS types?
contributions more than welcome :wink:
/edit corrected link for moved page
Right, better late then never…
Specs on VOTI (www.voti.nl) encoders;
M-SW-ROT, detented rotary encoder, price EUR 1,19
Encoder mode: “DETENTED2” (not 100% sure will verify later)
pinout;
http://www.voti.nl/docs/rotary-encoder.jpg
if you view the encoder from the top with the pins pointing towards you;
left pin goes to D1 (highest numbered din pin)
middle pin goes to D0 (lowest numbered din pin)
right pin goes to Vs
the detent can also be removed
cheers, marcel
edit// oh dear :-[ just found out the pinout i gave is wrong! been standing here for over a year now, so if any of your boxes work backwards you know who’s to blame
it’s fixed now
This is reference material, so appropriately it is in the Wiki - http://www.midibox.org/dokuwiki/encoder_specifications?s=encoder
Can we “un-sticky” this topic?  Further contributions to this should be made in the Wiki.
i think this would be added
http://www.soundwell-cn.com/ebusiness/en/product_detail.asp?catalogid=4&productid=65
yup, i already added it  :slight_smile:
Uhm is it just me or is this topic already unsticky?
Smash beat you to the punch :slight_smile:
Nice to see you back!
