I’m not sure about the max. PPR rate, it’s hard to create an equation that estimates this value, as it depends on different parameters: rotation speed, axis size, pulse width… the only spec that I can give you is that MIOS is able to sample for transitions every microsecond (-> specified with MIOS_SRIO_UpdateFrqSet).
However, from my experience rotary encoders which are specified with up to 36 PPR are working w/o problems. I haven’t tested “faster” encoders yet. (Note the the resolution will be doubled by the driver to 72 PPR)
to the encoder order: at least the prices would be interesting.
