encoder+ledbar instead of motorfader
Wondering if it would be possible to use  rotary encoders with ledbars instead of motorfaders in LC emulation?
Yes! :slight_smile:
btw can more than 8 leds be used per ledbar? =)
Yes, it’s already possible to connect up to 16 LEDs for each ring/bar. The patterns are free definable (see http://www.ucapps.de/midibox/mk_syx.zip , the midibox16e.ini sample file). The LC emulation will offer the same features (and a little bit more ;-))
Another fine idea from Serum
Question By adding 16 encoders for volume and 16 for the usuall parameters is it possible to have the code so the final midibox will be recognised from Logic as Logic contron + extention (meaning  16 channels in one box no master volume)?
(i assume I need 2 cores for this project)
Unfortunately this is not supported by the MC/LC protocol. Every device requires a seperate MIDI In/Out :frowning:
