"enc_example3_v1_3" dont work in MPLAB
Hi all
I’ve problem with loading project to MPLAB. When I open MIOS Skeleton Small.mcp , MPLAB error is “file format is unrecognized”.
Please, give advice with this problem.
Thaks for your reply.
LX
I don’t have MPLAB and don’t know which file to load. But the file your referring to is empty.
Bye, Moebius
Hi, Moebius
I try to copy content of other *.mcp file from another project to “enc_example3_v1_3” *.mcp. It’s work perfectly, I can load “enc_example3_v1_3” project in MPLAB. :smiley:
Thanx for your help.
LX
Moebius,
Are they anything more than just the “batch” of source files that went with the project? I usually just open the main.asm and/or any other source files I’m interested in and compile via MPASM. I’ve imported the full list of source files in MPLAB before, but usually don’t work with “projects”. It would seem like if he opened an alien mcp and it worked just the same, there wouldn’t be much point for our purposes, but I barely know the full MPLAB IDE.
I’ve wanted a way to see and trace the connections between Thorsten’s files and get a better idea of the program flow, but figured it wasn’t possible when there was supposed to be hardware, interrupt, and user interaction involved.
Maybe that’s it. ???
                              Thanks!
-George
