Enabling 'Edit Mode' on the Sammich?
I’ve just finished building my Sammich and I love it.
The only problem I’ve found is that I can’t save NRPN changes I’ve made to a patch while using a BCR-2000 to alter the sound parameters.
From the documentation, it implies I need to enable ‘Edit Mode’ by pressing ‘SHIFT + DOWN’. But it looks like the down cursor arrow on the Sammich is a ‘Page Down’ rather than the equivalent of DOWN on a MidiBox Sid, which means ‘Edit Mode’ is inaccessible. There doesn’t seem to be a CC/NRPN/SysEx command to enable it either.
Am I missing something, or is there a way around this problem?
Thanks,
Graham
While there is no LED to show the state of “Edit Mode”, it definitely does toggle “Edit Mode” on/off if you hold down SHIFT and press the down arrow.
“Edit Mode” is not the only way changes get saved, you can explicitly save via the “SAV” menu. Using “Edit Mode” can lead to accidentally messing up your patches and losing the original patch, which is why explicit saving is preferred.
I haven’t played around much with setting parameters via NRPN, but I’m pretty sure if you can see the param changed in the menu, it should be saved in the patch via explicit saving or via “Edit Mode”. Also, “Edit Mode” only saves when you change the patch, it’s not saving the params continuously after each change, etc.
