'ELO board run through
Any questions or comments, let me know.
Best,
Andy
Pretty nice job! Very Abstract Concept that may find a lot of possible practical uses. (Who said Modulbox-ng?) Design very compact and chainable , and SMT pitch sounds accessible to hand soldering. Maybe surface mount transition for MBHP has already started ^^? What’s about the BOM? i guess some 74HC*** but i wonder about capacitors/resistors when i see footprints? also SMT?
Good to see you managed to deal with HSV<>RGB conversion (wrote any conversion function? how did you passed H+V values in the end?). Good to hear about the voice comment too, helps a lot.
About taste, I especially love OLED 45° integration . One last question,at your advice would the encoder brightness be enough for daylight playin ?
Once again, pretty impressive!
Bests,
Jerome
Thanks, I hope that it’s interesting for people. You could also choose to leave out things, e.g. no displays, no touch sensors, no LEDs or even no encoders.
In this case it was necessary to go to SMT to mount components on both sides. It’s really not difficult as long as your solder is ~0.5mm for SOIC parts and you have flux on hand.
The 8 chips are hex inverters with Schmitt trigger inputs (74HC14) and three gates are used per sensor. Square pads are resistors, rounded pads are caps, and there’s two diodes in series in SOT-23. That way you can’t reverse the polarity :).
This is all TK.'s work here and here. Looking at the first one, maybe that’s easy enough for me to hack some mods in.
A couple of mistakes, but it’s the easiest way to explain.
I can’t take credit for this, but it is a cool way of fitting displays in and have the corners “point” to the correct encoder.
I mentioned in the youtube description that these knobs are not the “preferred” transparent “Waldorf” type. You’ll get much more light out of them (especially the sides) using these, although the diffused effect is also nice. It’s always very difficult to capture LED colours; I think the video does a pretty good job but your eyes are better live than via 1080p video :).
A last (but not least) question : Is PCB eurorack compatible? (size?)
Bests,
JK
good job!
i like the shading from dark to full brightnes with one color and that Pan-style with shading with 2 colors.
i am very interested into boards.
greats mike.
Bests,
JK
Board is 100*150mm, no problem for Eurorack.
10 hours ago, Phatline said:
good job!
greats mike.
Thanks! 'ELO is pretty much ready to go, I just need to confer with Peter whether that’s a good enough start for Programma or if he wants to work on the concept a bit more. If you’re interested in PCBs and your own development I can send you some. The display driver is fine – with one small bug that I mirrored the J15A connector. Not in the board file this time, but months before in the schematic…  It needs a workaround by either attaching the header pins to the bottom of the PCB or twisting pairs on the ribbon cable (only the first 6 wires of J15A).
Best,
nice. well done
Excellent work Andy!
I personally find the dark -> one bright colour  the most “readable” and logical for unipolar values i.e. 0% -> 100%
For bipolar values I think:
Left bright colour -> centre dark <- right birght colour
would be the most readable and logical.
Its great that we can change the script to suit our individual needs.
Great job man, can’t wait to get some boards soldered up! :slight_smile:
Have a great day,
Peter
How to do illuminated encoders (pots) if you’re Waldorf:
Quite classy, and uses an interesting lens to shine the light upwards.
They’ve even got the bipolar red/green going.
