Easiest way to start with CORE_STM32
Hi!
What is the fastest way to learn to program CORE_STM32 Module?
I have programmed some C code before, but not on a micro controller. So I’m more used to program assembler on PIC an such.
I have ordered a core32 kit and pcb, that i hope will arrive soon :slight_smile: Until then it would be nice to be prepared.
What type of development systems are you using? What is the easiest to get started with?
And how about the use of freeRTOS, why do you need a OS on a microcontroller? Wouldn’t it be easier and and faster code you just skip the RTOS? To me it just seem like another hurdle to get things done.
To read the tutorials step by step: http://www.ucapps.de/mios32_c.html
We are using different toolchains, they depend on the OS (Windows/Mac/Linux). It’s explained in the MEMO
You won’t get in touch with FreeRTOS so long you don’t want to start timed/independent tasks.
The big advantage of FreeRTOS is the preemptive multitasking and synchronisation mechanisms (mutex) - if you don’t see an advantage with such methods (as explained in the tutorials), just ignore them. But I wouldn’t program an application without the provided features anymore. If you want to see the differences, just compare the PIC assembly based MBSEQ V3 code with MBSEQ V4.
Check especially how difficult it was to run slow LCD output “in parallel” with timing critical MIDI output - no problem with a RTOS
I gave you access to the hidden programmers section.
Thanks for your answer Thorsten!
I’m using windows7. So I downloaded and installed ‘MSYS’ and ‘CodeSourcery G++ Lite’.
Now I got stuck on the ‘PATH Environment Variables’…
I don’t have the variable ‘PATH’ under User variables. Should I create this variable?
And should you really empty these PATH variables? and click ok?
And I don’t understand this sentence…
Now we can work with just the one PATH variable and continue to ensure that the required directories exist in the path in the right order.
All these settings of all variables feels like some black art… :slight_smile: It’s feels like something can go very wrong here.
Sorry, I can’t help here, I’m not a Windows user.
If you don’t have a USER Variable called “PATH”, just create it. Windows will automatically add it to the end of the system variable “PATH”.
As long as you don’t mess about with the system path, you can’t really break anything. The order isn’t that important, it becomes more important if you have multiple versions of the different utilities like make etc.You just need to make sure that the MSYS bin directory is in the path. (CodeSourcery should set the system path itself)
Cheers
Phil
What exactly is it you do in…
http://www.midibox.org/dokuwiki/doku.php?id=windows_mios32_toolchain_core
…under the section…
To me it seems like you don’t need the variable ‘PATH’ under User variables.
Is this correct?
Under the section…
Additional Environment Variables,
you should create some new variables. I can’t find what the name of these variables should be?
Is it 2 variables, one with the name ‘DOS’ and one with the name ‘MBHP_CORE_STM32’ (without the ending semi colons ‘:’ )?
Is this correct?
Not exactly.
The System and User environment variables effectively do the same thing. System is “system wide” and User is configurable on a “per-user” basis.
As a MINUMUM, one of those (system or user) must have “;C:\MSYS\1.0\bin” and “;C:\Program Files\CodeSourcery\Sourcery G++ Lite\bin” The reason I said add this to the user environment is that you can’t then break anything “system wide” if you do it wrong :slight_smile:
Under the section…
The instructions aren’t very clear I admit! What you need to add (in the user section) is:
Variable: Value:
MIOS32_PATH x:\path\to\trunk
MIOS32_BIN_PATH x:\path\to\trunk\bin
MIOS32_GCC_PREFIX arm-none-eabi
MIOS32_FAMILY STM32F10x
MIOS32_PROCESSOR STM32F103RE
MIOS32_BOARD MBHP_CORE_STM32
MIOS32_LCD clcd
If I get time, I will try to add some screenshots and improve the wiki instuctions!
Cheers
Phil
Ok! I don’t know where to post this…
but the link to download ‘ActiveState ActivePerl’ is dead in the following document
http://www.midibox.org/dokuwiki/windows_toolchain_svn
It surly is many steeps to get started :slight_smile:
Perl is only “required” if you wish to “make dist” MIOS apps. I thought you were developing for MIOS32???
If you “really” want perl, you could always try http://www.activestate.com
Obviously putting a direct download link to make things easier for people can backfire when the download location changes :slight_smile:
Cheers
Phil
Ok! So thats not for mios32? I have a hard time to understand all this :slight_smile: I’m totaly new to all this midibox stuff, so I don’t know the history behind it all.
so… http://www.midibox.org/dokuwiki/windows_toolchain_svn … it’s about the 8bit stuff?
So after I have followed the guidelines here…
… whats next?
Under ‘SVN Repository’ in the above page, was a link to this http://www.midibox.org/dokuwiki/windows_toolchain_svn
So I thought that I needed to do the stuff there to get access to the repository :frowning: Somewhat confusing.
Hi!
I guess that the right way to download the repository
on windows is the following…
Download and install TortoiseSVN from their downloadpage http://tortoisesvn.net/downloads
Create a new folder to save the code from the repository in. For a basic setup, create the following
c:\mios32\
Left click on th mios32 folder and choose ‘SWN Checkout…’
In the field ‘URL of repository’, paste the following…
svn://svnmios.midibox.org/mios32
and click ok.
Now, at any time that you want to update the repository,
Left click on th mios32 folder and choose ‘SWN Update’
Ok!
I want to thank everyone for their help :slight_smile: After I’m finished with all the basic steeps I think I will make an document about all steps I have done. That will make it easier for now ones, like me :slight_smile: And you don’t have to answer all the questions one more time…
Now for the next steep…
Lets say that I want to compile the first example in the tutorial. On my computer it can be found here…
C:\mios32\trunk\apps\tutorials\001_forwarding_midi\
I have followed the steps in…
For the ‘Additional Environment Variables’ I have used the following…
Variable: Value:
MIOS32_PATH c:\mios32\trunk
MIOS32_BIN_PATH c:\mios32\trunk\bin
MIOS32_LCD clcd
Ok! so how do I compile the first steep in the tutorial?
I assume you’d open your command prompt, cd to the dir with the Makefile in it, then type make.
That one was easy :slight_smile: It gave me a good laugh of surprise.
Then I just have to wait for my CORE_STM32 board to arrive.
Then thats all for now…
CU L8er
Hi guys,
I like this thread, It has helped me setup the core tools on my computer and to input all the variables. One issue I am having and I am not sure where I have gone wrong. In CMD I can run make -version and I get the relevant information about make. But when I goto the .svn depo that I have installed onto my C: and goto the tut dir and then type make, I get an error saying that make is an invalid command or exe so on.
I followed everything here Core Toolchain Setup
Does any of the great programmers here have an idea of where I might start to look?
I have just got my Core32 and am willing to get the tuts started so I can complete this monster of a project.
Regards,
Evan
Those are the instructions for the Core8 toolchain. For Core32 see here: http://www.midibox.org/dokuwiki/doku.php?id=windows_mios32_toolchain_core
What a :frantics: nut. Thanks for that and I will just try again. lol
Cheers
ok ok, I am getting there but now when the tut asks me to edit PATH under User variables, I do not have a PATH under this variables. I understand that this PATH maybe different from pc to pc but how would I get this PATH to show? If I have to create a new value, what should be in this PATH?
Regards,
Evan
UPDATE: Since this I have just continued on and just added the PATH from system into user. I have made it to the end but I am still unable to use make.
Sorry to be a noob for everyone. Wish I could just get it to work. If you need any more information please just let me know and I will provide as much as I can.
If you don’t have a “User” PATH, then you can just create one. Alternatively, you can just add to the “System” PATH.
What error do you get when you type “MAKE”? This should work as long as the directory that contains make.exe is in one of the PATH variables above.
Cheers
Phil
Cheers
Phil
Hi Phil, C:\MSYS\1.0\bin ;C:\Program Files\CodeSourcery\Sourcery G++ Lite\bin this is the PATH that is under the system variables. Msys\1.0\bin has the make.exe inside it. The error I get is “‘make’ is not recognized as an internal or external command, operable program or batch file”
I had removed everything after I found out that I used the 8bit and not the 32bit tut. Once this has been done I cannot also run the make -version in command, This can only be run in the MSYS prompt now. Here is a screen shot of what is going on, Hope it helps.
