I need some bright, wide angle duo LEDs for my sequencer. As I need it for integration in buttons it would be good they are 3mm or shorter 5mm so i can fit it nicely.
I would appreciate if you can recommend some that you have tried. Thanks
ledtuning.nl
common anode though
Which one of their LEDs have you use? I see they have only 35° Bi-color LEDs, which is very narrow for button illumination..
i ve got the 5mm and the 3mm and they are both ok for the SparkFun rubber buttons.
