Dual SSM2044 PCB Bulk Order
Hi all,
**the original bulk order is closed - if you’re interested in participating in a future bulk order, you can enter your name on the bulk order page**
Seppoman proudly presents: The bulk order page for my new Dual SSM2044 PCB:
http://www.midibox.org/dokuwiki/ssm2044_pcb_bulk_order
Each PCB can make use of two SSM2044 Filter ICs (24db LP) and is perfectly suited to e.g. expand a MBSID V2.
More information and sound demos can be found here and here.
Before you sign on to this bulk order, a warning: This is not a suitable project for absolute beginners. The soldering isn’t very difficult, but you will need either an AOUT_NG (SMT soldering required), AOUT_LC or an AOUT module (which needs to be expanded with the bipolar option), or another type of CV source to control this module, in addition to the actual synth (SID/FM) you want to use it with. So a bit of soldering experience and knowledge about the MidiBox platform is definitely recommended.
Seppoman
hey
total was wrong already!
great job Seppo, thanks
Simone
Guilty as charged… I added my order, and created the ‘total’ row…then realised I had stuffed up my count, fixed it, and didn’t fix the total… doh! Sorry!
Since I am running the bulk order for the SSM2044, I should also add the following disclaimers:
  1. I believe I can get the SSM2044 cheaply in bulk, but there is no guarantee. However, there seems to be quite a lot around, so they’re not especially rare, I’m just pointing out that I haven’t actually bought any yet.
  2. Payment is by PayPal only, unless you live in a country that can’t use PayPal.
  3. I am no longer tolerant of people who put their names on a list and then do not reply to PMs or emails or do not pay a PayPal invoice. This is not going to be another “SID MEGASALE” where I end up with 200 spare SIDs because people stuff me around. If you do not regularly check emails more than three times a week, or if you do not have PayPal, or if you do not have the money now then please don’t waste my time.
This is sweet, thanks guys.
Luke
Thanks for making this happen seppoman, and for the great price of the pcb.
Asaf
Great. Thanks seppoman.
add mine…i’m not alone for the order  :slight_smile:
thank you Seppoman !
Sweet, I’m In.
Me too, thank you :slight_smile:
Yeah add me please… now I have a friend with payball  :wink:
you can do that yourself - just go to the wiki page and edit it.
and btw, from EU countries you can also use bank transfer to pay. As far as I know, EU legislation says that transactions in Euro currency mustn’t cost more than normal domestic transactions (don’t have experience with that issue, maybe someone can enlighten us? :))
S
S
this is true if you supply a correct IBAN and SWIFT (aka BIC) code
european banks are slowly adopting the same pricing for transfer but it may still be different from country to country.And of course this is valid only for Western Europe.
!!! failing supplying a valid SWIFT will make you pay the whole international transfer fee.
Simone
Seppoman
Awesome! I have been awaiting the release of this PCB for a bit now. Glad to hear it is becoming available. Thanks
Sorry if this is not the rightr place to post. I soon will read thru your wiki about the use but I have a quick question about wiring. Can you use this pcb connected to audio in and out jacks for seperate use on effects sends and such instead of having it directly connected to the synth. And is it possible to control with midi? I hope I am explaining myself correctly and excuse my CV noobish thinking.
This rocks, thank you so much!
Wilba: Per your note in the thread above, I emailed you to confirm my address and order, but haven’t received a paypal request for the SIDs yet- I’ll take it that you’re still gathering data and that I’m not lost in the shuffle, as can happen. Looking forward to it and thank you as well!
sure, it has audio input and output, so you’re free to connect these to some jacks :slight_smile:
You need some kind of CV source for it. In the Midibox world that would typically be one of the AOUT modules, which in turn is connected to a core running either the MBCV app or (more powerful and flexible) running the MBSID V2 app (this is possible without actually having a SID module).
S
thank you . this is great, fits in exactly with what i am planning .
Thanks seppo. So your saying that the audio comes out of the filter board directly? And then I would need the Aout hooked up to the core to get midi control? Could I use this simple setup with the MBsid V2 program without any additional parts that are normally used for MBsid V2? But just to be clear I must have an aout module to control the board at all correct?
Yes to all questions :wink:
S
