dual command from one fader
Just wondering if anyone can help.
Thorstens away and a little busy at the moment so i am trying to figure things out but not getting far as i have never had to or tried to assign a dual command to one controller in mb64e before and change the resolution.
I need to have an MSB command sent followed by an LSB command straight after when a fader is pushed, this is for my DAW software and allows a finer fader control.
the message sent is:
MIDI RECEIVE EVENT             DESCRIPTION
    0xb0, 0x00, vv                    fader value, MSB
    0xb0, 0x20, vv                    fader value, LSB
So my assembly on anything other than sysex commands is really bad so i started with this:
    ; This is a 10bit fader command for daw fader control
    ; B0 (Chan 1 Control/Mode Change)
    ; 00 (Bank select MSB)
    ; 00 (This is the Hex value from 00-7f = 0-127)
    ; 00 (This never changes)
    ; The second command is the LSB command
    ; 20 (LSB For Control 0 (Bank Select))
    ; 00 (This value increments in tens 00 to 70 then repeats this value = 0-127)
    ; MSB command
     movlw    0xB0
     call     MIOS_MIDI_TxBufferPut
     movlw    0x00
    ; LSB command
     movlw    0xB0
     movlw    0x20
Then after the call is the requirement for the MSB/LSB increment and decrement function when the fader is moved +/-
However i don’t understand how i would implement the command for that so i become stuck.
The other issue for me is this needs to be at 10bit resolution so i don’t know where i would change that for the mb64e.
Any nudge in the right direction would be appreciated, i want to figure how it would be done.
thanks
heres the midiox data when the fader is pushed up slowly, it has to be a 10bit resolution for the daw to accept it as its default without mapping it.
[fader decimal.txt](< base_url >/applications/core/interface/file/attachment.php?id=10353)
[fader hex output.txt](< base_url >/applications/core/interface/file/attachment.php?id=10354)
