Drum Kit, sounds change channel
I am using one of the Drum Kits
I trigger the sounds with Midi from Ableton Live
When I play, and sequence, the different sounds go to the two different channels L&R
so I can have different effects on Kick and hi-hat
But when I play the sequence, the sounds have “jumped” to another channel, either both on the same channel, or on opposite
Is it something I’m doing wrong?
Can I controll this.
I have RTFM, but I can’t find it anywhere
The RTFM told me, that you can control this with the VAs parameter :smile:
OK, now I get it.
Thanks TK :slight_smile:
