Some of you might remember following entry in the wishlist:
MBSID Control Extension: as discussed in http://www.midibox.org/forum/index.php?topic=5680.0, but I think that I will overwork the concept so that it is also useful for the other subsystems.
This control extension is something like a “breakout box”, which is dedicated for easy editing of bass- and drumline sequences. For the MBSID-Lead and MBSID-Multi subsystem it could be used as simple keyboard, for mutes/solo or for quick patch changes. We will see. I propably won’t start with this extension before next year - first I want to see MBSID V2 completely working.
My statements are still valid, but I’m still not sure about the best solution which fits for all needs.
E.g., what I don’t like on your proposal is, that a 4x16 LED matrix is not sufficient. Just think about all the possible setups. There is a 8 track drum sequencer, which controls 16 instruments. Accordingly, the LED matrix should consist of 16x16 LEDs - but are the increased frontpanel costs really reasonable?
And what about the remaining 3 SIDs which can run the same, or any other engine? How should they be handled? Thats really difficult to decide.
E.g., the for basslines and drum engines which are running in parallel it would be important that sequences can be switched back and forth without using an “instrument” button - means: all sequences directly accessible. Like demonstrated in bassline demo #3 where I’m using a common MIDI keyboard for this. In addition, it’s possible to control sound parameters with key velocity, which might be a strong requirement for a control extension - if it should replace the already working MIDI keyboard solution (?) - as well.
Another idea: if an additional PIC is used to control the extension, it could be connected to MBSID via CAN interface and act as additional bus master. This would not only allow to access MBSID, but also other MIDIboxes, like for example MB-808?
And to give you more insight into my secret plans (
): one of the next things I want to evaluate is MIDI-over-IP, since it’s natively supported by MacOSX, and not only useful for sending MIDI control data, but also to handle the OSC protocol (useful for windows users as well, e.g. Reaktor supports OSC). So, the control extension could provide an ethernet option as well. And this would make it to a real universal solution, which is worth the DIY effort.
