Does anyone happen to know what the size of the Drill holes are on SmashTV’s PCBs? I can’t seem to find my tape measure, and I’m looking into getting some adhesive PCB supports for mounting the boards in the case.
Anybody have any parts they recommend or any experience with Adhesive mounts they’d care to share?
I’m guessing they are 3/8". If they are, I’m thinking of getting these supports.
http://tinyurl.com/5k6ql
Sean
I know this one! ;D
4.1mm
It’s just a touch smaller than 3/16" in imperial measure.
Best!
Smash
The 3/8" is the length of the mount, not the diameter of the pcb mount holes. The diagram shows that they fit .156" holes which is 3.96mm, So I’d guess they’d work fine.
Justin
Thanks guys…
so does it meant hat the part that I pointed out is the correct size? So do all PCB,s pretty much have the same drill hole size for supports?
So the difference in the size of the supports at Mouser it the support’s height then?
Thanks guys…
Yes
No, but all of my layouts use 4.1mm.
Yes, you are correct. Check out the catalog page for a dimensional drawing.
Best! ;D
SmashTV
