DOUT trouble
On some pins of 74hc595 measured +5V after power-on. But there are must be 0V.
I have insert this code to application source
void Init(void) __wparam
unsigned char i;
for(i=0;i<128;++i) {
   MIOS_DOUT_PinSet0(i);  // Set ALL DOUT pin to 0
void MPROC_NotifyReceivedEvnt(unsigned char evnt0, unsigned char evnt1, unsigned char evnt2) __wparam
  // check if note on or off event at channel 1 has been received
  if( evnt0 == 0x80 || evnt0 == 0x90 ) {
    // if note off event: force evnt2 to 0 for easier handling of 'LED off'
    if( evnt0 == 0x80 )
      evnt2 = 0;
    // number of DOUT pin in evnt1, value in evnt2
    MIOS_DOUT_PinSet(evnt1, evnt2 ? 0x01 : 0x00);
  if (evnt0 == 0x90 && evnt1 == 0x40 && evnt2 == 0x01) {
     MIOS_MIDI_TxBufferPut(0x90); // Send to PC DOUT pin state
     MIOS_MIDI_TxBufferPut(i);  //
     MIOS_MIDI_TxBufferPut(MIOS_DOUT_PinGet(i)); //
and after send “90 40 01” to device i get this
90 00 00
90 01 00
90 02 00
90 40 01
90 7F 00
If I send any 90 xx 01 - on DOUT pins nothing is change.
DOUT module tested for bad soldering - all elements soldered good.
You forgot to initialize the SRIO driver, see also the Init() function of this example:
http://www.ucapps.de/mios_c_set_dout.html
I have this code in Init Function:
MIOS_SRIO_UpdateFrqSet(1); // ms
MIOS_SRIO_NumberSet(16);
I upload “midibox64” application to core, and nothing changed.
May be 74HC595 are broken. But all 8 pieces?
May be truble in PIC? How can I test PIC on working capacity?
All MIDI events go from PC to CORE and come back (if I write necessary addition to MPROC_NotifyReceivedEvnt function).
I dont know to do…
I have upload “srio_interconnection_test_v1b” and check the interconnections to the DIN and DOUT module with a multimeter.
The Pins are mapped to following Modulation Wheel Values:
  # 0: Pin CORE::J8:DO and DOUT::J1:DO = ca. 5V - OK!
  # 1: Pin CORE::J8:SC, CORE::J9:SC, DOUT::J1:SC, DIN::J1:SC = ca. 5V - FAIL!  (measured only 0.72V (on pin #22 of PIC too))
  # 2: Pin CORE::J8:RC, CORE::J9:RC, DOUT::J1:RC, DIN::J1:RC = ca. 5V - OK!
Is It a PIC problem? How to solve this problem?
trouble with PIC pin #22 solved (short circuit with another pin)
but DOUT module still not work properly.
I don’t know what happen? but it WORK!! :slight_smile:
Yay :smiley:
